It is currently Sun Feb 01, 2015 3:14 am
 Post subject: Blowhole placement question
PostPosted: Mon Nov 01, 2004 4:58 am
I'm looking to add some cooling to the following setup, and would like some suggestions. I have this case: http://www.newegg.com/app/ViewProductDe ... 122&depa=0
With the following in it:
P4 2.8 with Zalman CNPS700A-cu cooler
ASUS P4P800 DX
ATI 9800 pro with Arctic Cooler
2x Enermax 120mm
DVD ROM
CDR
120gb SATA HD
Santa Cruz Soundcard
Netgear NIC
My question is. Where should I put a 120mm blowhole? Should I put one on top sucking out, or on the side blowing in? Thanks for any suggestions.
PostPosted: Mon Nov 01, 2004 5:21 am
IMHO a 120mm(or an 80mm) blowing in on the side
that case already has a decent amount of air flowing out..1-120mm and 1-80mm(PSU) . If you added another fan blowing out the 120mm inlet won't be able to bring in enough cool air :)
PostPosted: Mon Nov 01, 2004 5:29 am
I'm guessing that it should be blowing on the AGP slot, correct? Thanks for the help. -Mac
PostPosted: Mon Nov 01, 2004 5:52 am
roughly around here to give all the PCI and AGP good coverage :)
PostPosted: Mon Nov 01, 2004 6:11 am
Thanksfor the help! -Mac
PostPosted: Mon Nov 01, 2004 6:54 am
you're welcome :)
post back with your results(before and after temps)
PostPosted: Mon Nov 01, 2004 2:21 pm
Team Member Top 100
Team Member Top 100
I have the same case as you do, and I put a 120mm fan blowing right about where your pic shows.
My setup is similar too (2.8c CNPS7000A-AlCu, 9800pro, Asus p4p800se), and when I installed the fan on the side of the case it brought my case and cpu temps down 5 - 10C depending on the temp outside of the case.
PostPosted: Tue Nov 02, 2004 5:38 am
Thanks a lot yall. I should have some time this weekend to cut the blowhole. I'm also going to cut the built in fan gaurds out, and maybe get a little more air-flow as well. I also need to tidy up the wiring a bit. Man, a simple blowhole is turning into an all day affair. I'm gonna need more than a six pack. :P I'll keep yall posted with temps, and maybe a few pics. Thanks again! -Mac
