It is currently Tue Jan 27, 2015 10:54 pm
 Post subject: Shine and Protect your case?
PostPosted: Sun Oct 10, 2004 6:34 pm
I have a black metal case (TT Xaser Skull) and I was wondering if there is anything I can use on it to give it more shine and protect it from fingerprints. Thanks!
Cabal468
PostPosted: Sun Oct 10, 2004 7:18 pm
Car wax?
PostPosted: Sun Oct 10, 2004 7:51 pm
clear gloss enamel, spray, preferably Rustoleum (my weapon of choice).
PostPosted: Mon Oct 11, 2004 6:01 am
urmumsacow wrote:
Car wax?
I actually thought about car wax but I figured that would make it a little slippery! :lol:
 Post subject: Rustoleum
PostPosted: Mon Oct 11, 2004 6:05 am
Is it best to spray it on directly or spray it onto a cloth and apply it?
PostPosted: Mon Oct 11, 2004 7:59 am
No Hope = No Fear
No Hope = No Fear
Don't see where car wax would hurt it... my antec sanata came with wax... lol
Click HERE
Exterior Finish: Beautiful, glossy black. Better finish than most cars. The case does show fingerprints, so keep a cloth (and a bottle of carnauba wax) handy when working with the case. Bring this puppy to a LAN party and it will stand out amongst all the garish neon-glowing plexiglass monsters like a Tuxedoed James Bond at a Las Vegas casino - all class and style. Other reviewers disliked the "Antec" drilled in the side of the case; I don't mind it so much, though it does defeat the air filter somewhat.
PostPosted: Tue Oct 12, 2004 5:02 pm
Almost sounds like the Silverstone 'Gloria' case. I got that not too recently. It's beautiful, but not very well thought out on the inside. From what I have seen, that antec stomps all over this case in terms of layout.
This case (the silverstone) uses 120mm fans too, BUT the crappy 'grille' for the intake and exhaust is too restrictive. Even with the fans at full speed they hardly moved any air. I had to take the ol' dremel to it to fix that problem.
 Post subject: Thanks!
PostPosted: Tue Oct 12, 2004 8:10 pm
Thanks to everyone for the input! I think I'm going to go with the rustoleum idea, that seems to be the easiest solution.
Cabal468
 Post subject: Re: Rustoleum
PostPosted: Wed Oct 13, 2004 6:50 am
I would spray it on. Clothing it on you might miss spots and it wouldn't look right. you want to get an even coat. or it will look odd.
