It is currently Tue Mar 31, 2015 6:08 pm
 Post subject: Repainting an Old Computer Case Panels... QUESTION
PostPosted: Thu Oct 07, 2004 8:59 pm
No Hope = No Fear
No Hope = No Fear
I am tryong to re-paint an old case of mine, and i wanted to completely remove to old paint from the side panels... any thoughts one what works good? I was "possibly" thinking of trying some BRAKE FLUID to remove the paint, but I want to see if anyone else has a better idea.
:wink:
PostPosted: Thu Oct 07, 2004 9:00 pm
No Hope = No Fear
No Hope = No Fear
sorry bout the grammer, its getting late... my eyes are playing trix on me... :oops:
PostPosted: Thu Oct 07, 2004 9:42 pm
I believe a simple paint stripper or paint remover should work alright.
PostPosted: Thu Oct 07, 2004 10:43 pm
yea, heck even a sander would probably do a better job.
Brake fluid is some of the nastiest, most corrosive shit around. You dont want that on your paint and you DEFFINETLY dont want some tree huger seeing you slaver that on your case.
PostPosted: Tue Oct 12, 2004 6:08 am
No Hope = No Fear
No Hope = No Fear
found this stuff in the automotive section in wallmart...
i sprayed it on the panel and in seconds the paint was bubbling up and sliding off.
WARNING: do not let this stuff contact your skin... "it burns!!" :)
