It is currently Sun Jan 25, 2015 6:44 am
Post new topic Reply to topic  [ 105 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Fri Aug 18, 2006 9:06 am
Monkey Federation (Top 10)*
Wait... Where does the engine go now?
PostPosted: Fri Aug 18, 2006 3:03 pm
I have no idea about the engine. I think I'll have to skip it.
I got the matching keyboard and mouse combo
And I bought the custom Dodge etch from Crazy PC
Then applied it to the window.
Then I got the hole saw for the exhaust fan on top.
The hole saw was actually too dull and I had to finish with the dremel.
I then fixed the bad hole and applied the flat black.
Then peeled off the tape.
And used the pin striping.
PostPosted: Fri Aug 18, 2006 3:42 pm
Will it fit inside?
Or better yet...
Can I have it? lol
PostPosted: Fri Aug 18, 2006 4:12 pm
Will it fit inside?
Or better yet...
Can I have it? lol
Scrounge!
I hope you're submitting this build to MaxPC for their mod of the month. You've done some really sweet work and gone the extra mile to stay on theme. Reading through your posts is like watching Bob Vila craft something great... without the ghey!
PostPosted: Fri Aug 18, 2006 4:22 pm
Beta Tester
Beta Tester
Location: I don't suffer from insanity... I enjoy every minute of it
so far looking great!!!
the only thing I was going to suggest was the Mopar sign, paint the grill black and leave the M unfinished/silver/chrome
also since the disc drive and gauge cluster is a bit offshade/sheen of black, it is easy to pop them off and paint them as well.
PostPosted: Fri Aug 18, 2006 4:40 pm
Yep, everything that comes in black will be changed to flat black to match the case. I thought of submitting it to MaxPC, but they've never emailed me in the past and I don't think they would here either. Maybe I will send you that engine Spider Monkey.......
Here's some pics with the new scoop. This is just so you have an idea. I still have to replace the mesh and make the black match the case.
PostPosted: Fri Aug 18, 2006 4:49 pm
Lookin' good!
P.S. Stop being a bad son and send the Clowned PC to your mom. lol
P.S.S. - Gimme da motor! ;)
PostPosted: Fri Aug 18, 2006 5:21 pm
Where'd you manage to find a keyboard mouse that matched the color so perfectly?
PostPosted: Fri Aug 18, 2006 5:25 pm
I'm gonna guess that he found it on the intarweb...... But I could be wrong. :P
PostPosted: Fri Aug 18, 2006 7:50 pm
Aspire makes the case and keyboard and mouse :D
I replaced the mesh for the Hood Scoop.
And I painted the Hood Scoop to match the case.
Then I drilled out the screw holes .
Then I put the fan in and blackened the screws.
Then put the Hood Scoop perfectly on. :D
PostPosted: Fri Aug 18, 2006 11:43 pm
MUCH better than what the scoop came with! :D
PostPosted: Sat Aug 19, 2006 1:57 am
Well I woke up at 3:00 a.m. and couldn't fall back asleep so...
Just to see what it looks like, I added the drives
Then I hooked the top exhaust fan to a test PC to see it lit up.
Lastly I fixed the pin stripe so that comes from the Superbee logo and goes clear to the end of the case.
PostPosted: Sat Aug 19, 2006 2:15 pm
I went to the hobby store and spent .99 cents on some lettering.
Which added some detail to the hood scoops.
Next came the window grill. First some primer...
Then the green on the mesh.
And I made the grill frame black.
Then I bonded the Mopar "M" to the mesh
And lastly I put it all together.
And then on the panel.
PostPosted: Sat Aug 19, 2006 11:53 pm
I'm waiting for my motherboard to arrive so while I wait I thought I'd get some "current progress" pics.
PostPosted: Sun Aug 20, 2006 2:53 am
Very nice indeed Good job on the Mod
PostPosted: Sun Aug 20, 2006 5:38 am
very, very ncie *this is coming from a mustang man...*
PostPosted: Tue Aug 22, 2006 6:19 pm
Will it fit inside?
Or better yet...
Can I have it? lol
I got another toy engine of the same size....if you want it
PostPosted: Tue Aug 22, 2006 6:50 pm
The scoop is my favorite feature, although I think the rest of the mod is great as well. How are you attaching the scoop?
PostPosted: Wed Aug 23, 2006 8:29 am
I sure hope u get that crap resolved with that jerkoff from ebay. I h8 when jerks try to rip people off like that.
PostPosted: Wed Aug 23, 2006 8:57 am
I'd rather be modding!
Yeah...Still, even without the MB, its impressive.
I'm pretty much done with ebay unless its as a seller. I'm tired of the spam and general crap with dealers/sellers.
Paypal basically sucks as well - I've disliked them for a few years now.
I do hope it gets resolved. Its a great Mod.
Mnata
