It is currently Tue Mar 31, 2015 4:30 pm
 Post subject: Modding a xbox controller
PostPosted: Thu Sep 30, 2004 8:17 pm
Hey there,
I was wondering if anyone here has done anything with a xbox controller or know a site that can help we do some things with it.
Does anyone know if u remove the front slot for the memory card or live, can u rewire it (the thing that the memory card goes into) so that u can put a digital time in it?
My plan was to cut open the circle on the big xbox controller open(back side) and then put a time in its plays. Also does anyone know where I can get a circle or custom make one so that it fits into the circle, also need a way to start, restart the timer.
Thxs for the Help
PostPosted: Fri Oct 01, 2004 8:32 pm
Also, does anyone know where I can get a digital time that can fit into that xbox logo on the big controller? I want to be able to controll the time where the diretion buttion use to be.
Thxs
 Post subject: Re: Modding a xbox controller
PostPosted: Sat Oct 02, 2004 3:59 am
I'd rather be modding!
Toidochysp is our resident Xbox guy. But, you might try here first:
http://www.llamma.com/xbox/Mods/xbox_mods.htm
They amy not have what you need, but they might give you an idea of what is easialy available
Manta
PostPosted: Sat Oct 02, 2004 6:14 pm
www.koolpcmods.com has some xbox stuff, so does llama, llamma is a great site.
PostPosted: Sun Oct 03, 2004 1:16 am
hey thxs for the help anyways, it was great of u guys for giving the link and now I have more ideas
PostPosted: Wed Oct 06, 2004 1:01 pm
you'll also want to check out xbox-scene's website for lots of tuts:
http://www.xbox-scene.com/tutorials.php?p=191|#191
PostPosted: Sun Oct 17, 2004 8:05 am
Manta
man this site is owesome...got to start doing some damage to my xbox....by the way half life novembetr 1st cant wait!!!
PostPosted: Sun Oct 17, 2004 8:33 am
did u happen to see my controller in my post about my xbox^PC
PostPosted: Sun Oct 17, 2004 4:13 pm
man that thing is owesome i was looking at your tread and you are good..and i really like the blue..good color choice..
i want to do it too...just got to find the time..
PostPosted: Sun Oct 17, 2004 6:43 pm
thanks man, i'm gonna add on to it soon, i got some more idea's i'm just gonna wait til i get my 3mm LEDs they fit a little better :)
PostPosted: Sun Oct 17, 2004 6:50 pm
Celeron
Celeron
hey... i've got an idea... what about making some air vents and have a small fan in the controller to keep your hands dry? (nYKo's idea)
PostPosted: Sun Oct 17, 2004 7:55 pm
dude, they make those already, just go buy another controller and use the fans from that.
