It is currently Mon Apr 27, 2015 5:26 am
 Post subject: Flightline
PostPosted: Sun Jan 19, 2014 9:00 am
 Post subject: Re: Flightline
PostPosted: Sun Jan 19, 2014 11:33 am
I'm throwing money at the screen but nothing's happening. :<
Though I'm curious, the blower appears to be pointing in the wrong direction.
PostPosted: Sun Jan 19, 2014 11:46 am
Thanks. The round inlet port is facing up. The exhaust is facing out. Here is another view, maybe this helps.
PostPosted: Mon Jan 20, 2014 8:31 am
Dude, that is an awesome case. It looks like something from the 1920s, art deco or something. Reminds me of those streamliner trains of that era.
Do you have a build log somewhere? What mobo/cpu is that?
That heatsink looks like the laptop-style ones. Like latios, I am confused at its position. It looks like the blower blows over the heatsink but it has no exit, except up above.
PostPosted: Mon Jan 20, 2014 8:38 am
Thanks!
Project Log
Specs:
Gigabyte GA-H77TN Thin Mini-ITX Motherboard
Intel i7-3770K Ivy Bridge CPU
Intel HTS1155LP Heatsink/Blower
Intel Lincoln Crest 240GB mSATA SSD
Kingston HyperX 8GB DDR3 1866
PostPosted: Mon Jan 20, 2014 9:38 am
Does this use an external power brick? It looks like there is a power connector port at the top of the mobo? Does the power brick come with the mobo or separately purchased?
PostPosted: Mon Jan 20, 2014 9:56 am
From the Gigabyte website:
Output Voltage: 19V DC
Output Current: 7.89A
Output Power: 150W
Input Voltage Range: 100V AC to 240V AC
Input Frequency: 50 Hz to 60 Hz
Connector:
Inner diameter 5.1mm
External diameter 7.4mm
Depth 12.5mm
I found a laptop power adaptor that works great.
PostPosted: Mon Jan 20, 2014 9:59 am
It comes separately, which on one hand is kind of piss poor on Gigabyte's end, but on the other it'd drive the cost of the motherboard up another $50-$90 no doubt. But it looks like those universal laptop power supplies do the trick.
