It is currently Fri Jan 30, 2015 9:47 am
 Post subject: Phantom 410 MOD - Project Log
PostPosted: Fri Aug 02, 2013 4:54 am
Welcome! This is a Project Log by jompenleet.
This project is closing soon and iam starting a NEW PROJECT in a Phantom 820 case.
The upcoming project will contain more reviews, pictures & tutorials.
I will be using the following from MNPCtech
24" x 12" Acrylic Sheet (Smoked)
http://www.mnpctech.com/acrylic_colored_sheets_casemod_windows1.html
24" x 12" APPLY 3M Di-Noc CARBON FIBER FILM
http://www.mnpctech.com/CarbonFiber_Gunmetal_Titanium.html
120mm grill Cable fan guard. This will only be used to locate where to drill holes for extra fans.
http://www.mnpctech.com/Wire_Fan_Grill_Guard_Chrome.html
U-channel molding about 8ft. Only to try if it improves the look of the side panel.
http://www.mnpctech.com/moddersmesh.html
24" x 12" Modders Mesh sheet round hole 60% airflow Might use alot of this
4x Silver Anodized Case Thumbscrew's 6/32 thread
http://www.mnpctech.com/thumbscrew.html
2 x Cable Management Grommet 1-1/2" Inner diameter 2-3/8" Outter diameter
http://www.mnpctech.com/PC_Cable_Rubber_Routing_Grommets.html
Sleeva.se supplied me with all the sleeving, cable ties & shrink tubes you'll see in this project
Timwill's graphical designer helped me design all the logo's and stickers you'll see in this project
This picture is one of the most recent
Though i recommend you to check the last page in the thread for more pic's
Here is the original state of the NZXT Phantom 410 case. (Just moved the components of my old OEM computer into the case)..
Got a new Motherboard + processor + cpu cooler (Scythe Grand Kama Cross)
After getting some new fans Xigmatek 1253 & a new fan to the cpu cooler Xigmatek XAF Series 140mm
it looks like this.
Interior before cable sleeving and cable management.
Here's a link to the tutorial i followed to be able to do this!
http://www.youtube.com/watch?v=WpZoE-zj0-k
:thumb:Thank's alot to MNPCtech for the really informative tutorials on case mods!! :thumb:
Interior after hardmod sidepanel + psu cover & fully sleeved cables.
Tell me what u think! :)
Im still waiting for my stormtrooper sticker & white LED tubes for the case
[b]UPDATE
Got sick of the orange LED fans so i decided to modify them abit..
First i took apart the case and looked around for fans laying around..
Found some!
case without fans :-(
Xigmatek F1253 and F1450 i think?
Cleaning the fans for the paint to stick
Safety first! (if u ignore this ur fans may not spin at all)
Removing the LED's
close up look..
Fans on top of the case
Scythe grand kama cross CPU cooler after painted the fan
overall look
Still waiting for stickers and Cold cathodes![/SIZE]
UPDATE
Got me some watercooling now.
And some new dust filters (the old ones sucked)
Made a Hole in the PSU cover for the GPU Cables
Also painted the Chassi details in Glossy White
Got two identical NZXT 140mm fans for the top (had too look symmetric)
Water cooling in place
So what the case currently looks like.. Ill be getting some more parts next week.
Also installed some Revoltec Cold Cathodes....
So i got some new stuff that my friend at timwill clothing drew for me..
He also had some contacts to be able to make it in this frosty nice look :-)
Here we are applying a new sticker to the acrylic side
finished!
Also got me some custom made fan stickers, drawn by David @ Timwillclothing
sticker on the modded 120mm xigmatek fan
stickers on the modded 140mm NZXT fans
[IMG ALT=""]http://www.overclock.net/content/type/61/id/1536947/width/350/height/700[/IMG]
Voila!
I do have some other things waiting to be done with this case (otherwise i wouldnt have this blue led still in there)..
UPDATE
Ok so i got me some new stuff.. More paint(oil based high glossy hobby paint as usual), cable management items & some velcro tape.[/size]
So. Take the case apart for starters.. Here iam removing the mesh from the trim[/size]
Ok! Done for now. I also removed the heatsinks of my Corsair Vengeance DDR3 kit. (this mod is still in beta phase. I do not recommend you to do this yet, since i don't know how stable this mod is) since painting heatsinks could isolate the heat back into the ram chips. Though i will be using 2 extra thin layers of oil based paint for this test.
Decided to go nuts with the spray can on all the black details of the case and ddr3 heatsinks to match the rest of the build.
2 thin coat layers of paint. After that i left them outside under a roof to dry for 15hours. Since some of these stuff are going inside the case it is very important it is totally dry
Im really happy with the cleanyness of the ram heatsinks! Hope they still work...
Ok! using super glue to put the front panel cover back on.. Shouldn't break for the next 10 years.
Will check back with you guys to tell you if this is the best thing on the market today..
Applying double sided thermal tape on the memory (The same way as the stock thermal tape was applied)
Ohhlalala!
Ok! Now everything is back together. Time for some end result shots.
Here is the first photo without side panel
Upper Photo
Front Photo
[IMG ALT=""]http://www.overclock.net/content/type/61/id/1559970/width/500/height/1000[/IMG]
Ram mod result Photo
With side panel
Will be checking back within the upcoming weeks with result of the ram mod. To see if i recommend it or not.
But this Phantom 410 project is soon to be finished. I just have some re-sleeving to do, also building a new PSU cover
Although i have already recieved a Phantom 820 case for my upcoming build.
So stay alert and look for Jonas "jompenleet" Undestam.
Have a good one
So stay tuned!
 Post subject: Re: Phantom 410 MOD - Project Log
PostPosted: Mon Aug 05, 2013 7:24 am
Ok so i got some new white sleeving from a company named Sleeva.se
i don't know if they ship internationally. I do know they ship all over Sweden anyway..
So here is what i ordered
Shrinktube Small White
Shrinktube Small*White
Shrinktube SATA White
Sleeve SATA*White
Sleeve Small*White
Cable-tie Brackets (10-pack)
Lamptron Modding Tool Kit
Some tools that will be used for sleeving
A heat-gun is a must if you've got white shrinktubes. Because they will get abit darkened if using a lighter.
Black shrinktubes don't matter though
Lock ring pincer (inverted) to open up the shrink tubes abit.
This was really useful
Starting off with re-sleeving a 24pin Bitfenix Extender.*
I did put an extra smaller shrinktube under the sleeving in each end for my white shrinktube to attach better onto the cord.
This is some really high-quality sleeve, can't see through it at all..
Finally finished with the extender.
Took me a few hours to be honest :P
This sleeve is abit thicker than the black stock sleeving on the extender so it'll look like this in the ends.
I don't care though
Sleeving is now complete, here is some results
Graphics card 2x 8pin connections
24pin mounted
8pin mobo
Scroll down for more pics
PostPosted: Mon Aug 05, 2013 7:25 am
So i decided to make a new PSU cover out of regular 3mm acrylic sheet (because any coloured one is impossible to get your hands on in sweden)
Ofcourse i started with measuring the dimensions of it inside the case, Length, Height and Depth
Didn't take any pics of that though
Here im cutting the pieces for the cover
Ended up with these, hopefully they'll fit now.
Had to remove the stock HDD cage though, because it was too high for my cover. Ill just use the dremel to cut it down abit. But thats a project for later.
Here is me drilling out the poprivets for the HDD cage. You'll also see my nice socks here
This is just a temporary solution to hold the PSU cover up and giving it some support.
I just bend a PCI cover top the same height as the PSU and used a pop rivet to hold it in place
So i found some 90 degrees set square's at work that is usually used to glue photo frames.
I think it'll work perfect for this.
So the paint has been drying for 2 days. Not because it needed to but i didnt have the time countinue with the work.
Now its as solid as a rock :-)
Preparing the acrylic for paint.
Using paper tape on all the edges to avoid getting any paint on there.
Fully taped
Ready for paint!
Lets do some magic
[img]http://www.sweclockers.com/image/gallery/2013/08/02/Img_9197.jpg?t=original&k=12eb601d/img]
After painting with my regular High Glossy White (oil based) paint it will look like this.
two layers of paint is enough, if the acrylic has been cleaned up before painting.
Here are the old & the new PSU cover
So i got the idea of trying out some engraving.
Since i had some extra acrylic laying around i thought i'd give it a shot.
Don't blame me lol because i've never done anything like this before.
Decided to put it here after i was done, now drilled some holes to be able to pop it there after i engraved the piece.
These are the tools i used. A rotary tool, some Diamond Grinding things, a decal & acrylic.
EDIT -  i found a flash light was also very useful for this
Getting the logo in place
Lets get started!
So much fun!!
Still going!
Result after 30min's of work
Results enlightened, if you look this close youll see 2 obvious mistakes. But this picture is very well zoomed. You wont see it if u look through the side panel of the case.
Atleast not me :-)
__________________________________________________________________________________________________________
End result, NO FLASH
END RESULT WITH FLASH
END RESULT WITH FLASH & SIDEPANEL
Will be doing some more small works on this, then im off to start with my Phantom 820 project wich will also be posted here on this forum.
Look around for Jompenleet!
Hope you liked it
PostPosted: Mon Aug 12, 2013 12:36 pm
Great looking build. Well done!
