It is currently Sat Apr 18, 2015 6:29 am
 Post subject: Need Help w/DIY Project
PostPosted: Thu May 23, 2013 5:29 am
Sorry if this is not quite "PC" but.....I would like to take my 42" HDTV that is getting replaced with a 51" HDTV and hang it on the wall like a painting. Insert a USB stick and have it cycle thru the pics loaded on it but have no idea how to start. It's just a tv. Do I need a program to run on the USB Stick? Has anyone done anything like this before??
It's a Father's Day gift so it means a lot and I would really appreciate any/all help I can get.
 Post subject: Re: Need Help w/DIY Project
PostPosted: Thu May 23, 2013 7:02 am
Have you looked into the android-on-a-stick option? Or Raspberry Pi? I think you can load up a slideshow program on them and hook it up to your tv.
PostPosted: Thu May 23, 2013 10:26 am
If it's a smart TV, it usually has a picture slide show application. If this is a more permanent thing, then yes, a Raspberry Pi would work.
PostPosted: Thu May 23, 2013 1:56 pm
Thanks for replies. It's a 4+ year old HDTV so I think it just has the basics. What I want would probably rely on a program running on the USB stick.
Optimally, I wanna hang my 42" HDTV up so he can just plug a USB stick into it and let it slide show thru all his favorite pics.
I went thru the HDTV's menu and such, wasn't much there as far as photo sharing. Gonna need help as in a program on the stick to do the slide show. Thanks.
PostPosted: Thu May 23, 2013 2:13 pm
There's a question of what that USB on the TV is even used for. If it's a service port, I hope you can find someone who did all the hacking for you. If the TV even has a USB port. Otherwise you will have to get something like a set top box or Raspberry Pi or something to do this for you.
PostPosted: Sat May 25, 2013 5:56 am
Dr. Lat you are correct. Only USB is a service USB. I guess I need something I can plug into the HDMI ports that will run the slide show. Anything like that out there? Gotta go to work.
PostPosted: Sat May 25, 2013 2:40 pm
This is the android on a stick I was talking of:
http://dx.com/p/ditter-v12-android-4-1- ... -961196906
It seems to use HDMI. I am not sure how they work but I guess you can load a slideshow app and run off it. It has 8gb capacity.
More details:
Brand DITTER
Model V12
Operating System Android 4.1
Chipset RockChip RK3066
Processor Frequency 1.6GHZ
Memory 1024MB1GB DDR3
Storage 8GB
Wi-Fi IEEE 802.11b/g
Bluetooth 2
OTG yes
Memory Card Type TF
Max Extended Capacity 32GB
Audio Formats MP3,WMA,OGG,FLAC,WAV
Video Formats ts / m2ts / tp / trp / mkv / mp4 / mov / avi / rm / rmvb / wmv / vob / asf / flv / dat / mpg / mpeg
Video Codecs H.264
Picture Formats JPG, BMP, PNG, GIF
Subtitle Formats MicroDVD [.sub]
Output Resolution 1080P
HDMI 1.3
USB USB2.0
Wireless Keyboard/Mouse 2.4GHz
Video Output HDMI
Audio Output HDMI
Power Supply 2-Flat-Pin Plug
Power Input 5V/2A
Android Market Download Yes
Compatible Application Youtube, Skype
PostPosted: Mon May 27, 2013 5:34 pm
I remembered I have an old netbook that I haven't used in years which has a VGA port and so does the tv. I can easily run a slide show program on the netbook, it will be perfect. A 42" wall mural.
