It is currently Mon May 04, 2015 3:14 pm
 Post subject: Project Haswell
PostPosted: Thu Mar 21, 2013 10:30 pm
Hey guys I am starting a new project except this one is actually going to be for my personal daily use computer.
This will be a completely customized Cosmos II that will not resemble the original Cosmos except for some slight resemblance)
Sponsors for this build are:
Cooler Master
MNPCTECH
List of parts to be used:
Cosmos II
3 EVGA GTX Titans(hydrocopper) in triple SLI
Motherboard: to be determined but it will be a Haswell chipset motherboard
CPU: Haswell (to be determined upon release)
Swiftech GPU waterblocks
CPU waterblock: Swiftech
PUMPS: 2 Swiftech pumps
Reservoirs: to be determined
Rads: 1 480, 1 360 & 1 240 (to be determined)
Fans: Cooler Master Excaliburs
PSU: to be determined
Sleeving: MDPC
Coolant: Alphacool pure water and Mayhems to be determined
SSD's: 6 SSD's in RAID 0 possibly Plextors or Samsung Pro series[/I][/B][/SIZE]
[URL=http://www.mnpctech.com/CoolerMaster_Cosmos_2_Clear_Side_Panels.html]Mnpctech Pre-Ordering page for Cooler Master Cosmos II Clear Window Panel
[/URL]
Basically I am completely stripping down this case, removing the midplate and fabricating my own based on the motherboard when it is released. Also the entire front I/O shield will be deleted and a 480 rad will be mounted there after I delete the entire 5.25" bays and the HDD bays. I will be using a custom overkill grill from MNPCTECH on the intake. I will be mounting a 480 rad up top and also using an MNPCTECH overkill grill there after I fabricate the flush mounting solution around the current top panel.
Also I am almost sure that I will be housing both pumps down below in the PSU section of the case. The top handles will be deleted from the case as well as the roll bar type feet currently on the case. The side panel will be a solid custom acrylic side panel that will be mounted directly to the factory oem door hinge so you will be able to see every inch of the inside of this case mod.[/SIZE]
Here are some basic pictures of what I have deleted so far out of the case. (Definitely getting rid of the Octopus front I/O shield, just has way too many wires for my taste and I will be installing a custom fan controller)
Well as some of you know I got in 2 of the GTX Titans today. I have to say these are the nicest looking and feeling air cooled cards I have ever owned. Swiftech blocks will be coming hopefully within less than a week as well as backplates. Here are some pictures
Have around 7 weeks to wait till 480 overkill grills so I can fab out the entire front bezel of the cosmos II as well as the top extension.
 Post subject: Re: Project Haswell
PostPosted: Mon Jul 01, 2013 7:53 pm
I'm still waiting to see what your going to do with those 2 Quad Nautilus grills. Your building choppers aren't you? Busy, busy
PostPosted: Tue Jul 02, 2013 9:28 am
Looking forward to when you can resurrect this project, Brian 8)
