It is currently Fri May 24, 2013 1:26 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: idea
PostPosted: Sat Jul 31, 2004 3:03 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
hmmm..... i got a pretty cool idea, get a clear case or one with a window and put a mini disko ball, with a motor to make it spin, and a light. LoL i am stupid :roll:
PostPosted: Sat Jul 31, 2004 3:37 pm
Hey, whatever floats your boat. That's what modding is :D Don't try to impress others, or you lose sight of what modding is about. If you try to build using everyone else's likes, you'll have a clear box with lights all over it...just like everyone else.
But you CAN double check tastes if you're really at a delima. I've done this recently because I couldn't decide weather to paint over an already pretty aluminum finish.
With the disco ball, it'd be a bit expensive if it doesn't already have a little spinning motor. The only slow motors I know of are stepping motors that are geared down for high-torque applications and can get way up there in price. Gutting another device with a slow motor in it may be the better idea.
Another problem (I'm being a pessimist) is that the roof of cases is usually full of crap and is the hardest area to clean up. The Power supply is up there and the opticals, so it's just a weird area to get clean.
I say do it if you're the disco duck!
PostPosted: Sun Aug 01, 2004 6:14 pm
Hey I got a solution.
Get a 9volt batery and a small motor from an old cd drive or a wind up motor from a cheap music box and then scre it into the roof of your pc.
By the way it will look better in a full clear case maby with multi coloured LEDs. Ill stop now my minds starting to wander. :D
PostPosted: Sun Aug 01, 2004 7:29 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
lol the only prob with that is that it doesent power on wen the pc does
PostPosted: Mon Aug 02, 2004 2:57 am
wire it up so that u can hook it to the PSU ...
PostPosted: Mon Aug 02, 2004 3:13 am
Use a PCI relay like the ones for water pumps.
PCI Relay
PostPosted: Mon Aug 02, 2004 9:57 am
30 bucks for that!!! not a bad idea but it would be cheaper then to just splice into the power from one of your fans or hard drive. Or how about mounting a fan near the ball or mounting the ball near a fan and put a couple of fanblades on it. :roll:
PostPosted: Mon Aug 02, 2004 10:28 am
Most water pumps dont run off DC and I assume a motor for a disco ball doesn't either. This relay uses the juice from the PCI port to switch on the pass through AC connection ;)
DD makes a DC pump now though, in which you would be right.
cheaper, yes...
safer, probably not
PostPosted: Mon Aug 02, 2004 12:20 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
could i wire a connecter that would fit into the pcu on to the excisting motor wires??
PostPosted: Mon Aug 02, 2004 7:13 pm
You could take the advice from you're "soldering" thread and splice the wires to do this.
-3.3V wire and a +5v wire will get you enough juice to spin your ball. The trouble is finding a slow speed dc motor. Finding a small toy with something spinning on it is the best bet. Gut it out and supply it power. Whoe! clock motors are abundant and cheap. If you can find one where the second-hand has a fluid movement instead of "jumping" each second, you could use one of those! and they're like, less than a buck.
One of these things
And I guess are hard to find:p Here's a site to browse as well:
http://www.steebar.com/Motors.html
The little motors I can think of are noisy. And you want a disco ball to spin slowly to get the right effect, not fast. I'm not sure if an LED will be right, but you can try it. I can't think of a better idea than them:p
PostPosted: Mon Aug 02, 2004 8:13 pm
might be bad ass if it spins at 2500 rpm or so tho ...
PostPosted: Mon Aug 02, 2004 8:39 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
then you wont get the effect
PostPosted: Mon Aug 02, 2004 9:55 pm
it would just be faster ...
PostPosted: Tue Aug 03, 2004 12:34 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
then you dont get the dots goin everyware just a fast ball moving with some light
PostPosted: Tue Aug 03, 2004 1:41 pm
and you won't go into epileptic fits :D
PostPosted: Tue Aug 03, 2004 2:16 pm
heh heh, i still think it would look pretty cool, but u can look HERE for some slow moving motors.
PostPosted: Tue Aug 03, 2004 2:22 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
I love that site the prices are so cheap
PostPosted: Tue Aug 03, 2004 2:52 pm
a lot of the stuff they sell is used or refurbed, but it's all still in good working order.
PostPosted: Tue Aug 03, 2004 6:56 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
ur site scares me xhaos
