It is currently Thu Mar 05, 2015 11:05 am
 Post subject: Use laptop monitor for desktop pc?
PostPosted: Thu Jul 29, 2004 3:44 pm
My toshiba satellite 1805-s203 died. I want to salvage what I can by using the monitor with my desktop. Can anyone tell me how? Also, I am planning on incorporating my laptop's dvd rom with my desktop, but external to it. Do I need to set it up with a cooling fan or anything?
In case you haven't noticed, I'm just getting started and learning. Any help is appreciated.
PostPosted: Thu Jul 29, 2004 3:50 pm
i would like to know what it would take also, but my plan is for a in car PC and i figured that a screen out of a dead laptop would be cheaper than an LCD monitor. and i can get them in smaller sizes.
on the DVD-ROM, i would say no u wouldnt need cooling, they dont get any cooling in the laptop as far as i can tell, so i would think it would be fine. i may be wrong tho. even desktop optical drives dont reqiure much cooling if any.
PostPosted: Thu Jul 29, 2004 4:43 pm
i also have a laptop with working lcde, but not much else
you would have to look up the pin assignments and make a connector
PostPosted: Thu Jul 29, 2004 5:27 pm
I'm not sure if you can still find a sage2, but they make this really easy:
http://www.eio.com/sage.htm
Here's some other technical reading:
http://www.eio.com/lcdconnect.htm
http://www.hut.fi/Misc/Electronics/...nterfacing.html
http://www.geocities.com/p9019/lcdpanel.html
http://www.pesupport.com/cgi-bin/config.pl?read=176207
Search Keywords
Go Wildcats ;)
 Post subject: Thanx
PostPosted: Fri Jul 30, 2004 6:23 am
Thanx for the info. Looks like I got some reading for tonight :D
PostPosted: Fri Jul 30, 2004 10:04 am
sweet links...thanks
PostPosted: Fri Jul 30, 2004 6:56 pm
last I heard this was rather expensive. flat screen computer monitors have controls built into them which are specific to each maker and model. Because laptops don't have this feature (it's controlled by other means which aren't easily adaptable to PC's) you have to get a card to control the screen. You can check out www.mp3car.com for more details. While there are some makers of these cards for pcs, they remain pretty expensive. If you do find any alternative cheaper mothods please post them. I would also love to know.
