It is currently Sun Apr 26, 2015 5:37 pm
 Post subject: Extending wires on CCFLs?
PostPosted: Thu Mar 17, 2005 9:55 pm
I just got some new dual sound reactive CCFL's (Cooler Master) and wanted to extend the wires on one of the light to put it outside of the case. And after I cut and extended the wires only one side of the light was lighting and lighting up. I've tried different wires and no luck.
Is it supposed to be like that? Is the signal lost when I use longer wires, or am I doing something wrong?
PostPosted: Thu Mar 17, 2005 10:55 pm
Did you put the wires back on the same way?? Did you solder them well?
If all you did is add some power cable, it should still work.
PostPosted: Fri Mar 18, 2005 5:52 am
Will Mod for Scooby Snacks!
You had to do something wrong in your re-wiring... maybe you even shorted it out, static is a bad thing... there could be many reasons, but I bet it was a bad splice job...... not to get on your case about it, but we all make mistakes, threre have been many times I've had to re-do things, basically because I was in a hurry... we all make mistakes, learn from them!! And one thing to remember: Patience!! Especially anything to do with wiring!!!
I would say to re-check your splices, and maybe even just re-do the entire thing, being extra careful this time....
Start with new wires etc.. that's exactly what I would do...
PostPosted: Fri Mar 18, 2005 6:10 pm
Thanks for the comments, I'll try redoing it later.
I just wanted to add some more cable from inverter to the light.
PostPosted: Fri Mar 18, 2005 6:39 pm
Smithfield*
Smithfield*
are the wires the same gage?
PostPosted: Fri Mar 18, 2005 11:45 pm
No, I don't have any wires of the same gauge, but I've tried thicker and thinner wires. Anyway I'll try it again tommorow and see what happens
