It is currently Wed May 22, 2013 3:53 pm
 Post subject: Moving my Laptop Power Button [Help!]
PostPosted: Thu Mar 29, 2012 12:29 pm
OK. I am at a loss here as to what the part name is that I would even need to search for?!?
Background: I am converting an old laptop (Dell Inspiron 6000) into a digital picture frame. As such I would like to relocate the power button to the bottom of the frame. However, the laptop power button is a plug not a set of wires.
Required: I need to find an adopter that I can plug into the laptop board that can act as an extender to the power button piece.
Pictures always help....
This is the backside of the power button. I would need a 10-pin (very small) female adapter to fit into the male plug.
The opposite side of the adapter would need to plug into the male piece on the laptop board.
I am thinking the adapter would look something like this, 10 individual wires each with a male and female end....
I went to RadioShak and the kid had the most hilarious confused look on his face, needless to say he wasn't very helpful. If anyone has any idea on what I could use and where I might be able to obtain such an object, I would greatly appreciate the advice.
Thanks in advance.
 Post subject: Re: Moving my Laptop Power Button [Help!]
PostPosted: Thu Mar 29, 2012 5:03 pm
I'm thinking solder wire to some female headers (laptop side) and some male breakaway headers. This might be a source for the wire.
PostPosted: Fri Mar 30, 2012 4:38 am
Exactly what I was looking for, thanks noghiri_x. I appreciate the advice and links.
PostPosted: Fri Mar 30, 2012 6:30 am
Pins are usually standard. All you need is some solder and a soldering iron. You DO have those, right?
PostPosted: Fri Mar 30, 2012 7:00 am
:D Yes, I have a soldering iron and solder and the wire that you linked too.
I just didn't know the names "break away headers" which made the search difficult.
Before posting, I tried searching for computer pins but was not getting any good results.
PostPosted: Fri Mar 30, 2012 9:13 am
It's an Arduino/prototyping board thing. I'm not surprised you haven't heard about them. :)
