It is currently Fri May 24, 2013 7:51 am
 Post subject: SSD replacement to Samsung Series 7 HD
PostPosted: Fri Jan 20, 2012 10:57 am
I'm planing on buying a laptop in the near future, the frontrunner is
http://www.samsung.com/us/computer/laptops/NP700Z5B-W01UB
A Samsung Series 7 NP700Z5BH Notebook.
It comes with a 750gb HD, and I would rather place a SSD of some sort in its place. Has anybody here done the same, or know if it would fit in the slim case without extensive modding?
 Post subject: Re: SSD replacement to Samsung Series 7 HD
PostPosted: Fri Jan 20, 2012 11:12 am
You shouldn't have an issue with replacing the existing hard drive with a SSD. Most 2.5" drives will have the same dimensions, but you have to make sure that its the standard height of 9.5mm (12mm is another size). Newer ultrathin/ultrabooks have started to use more custom sized laptop drives/ssd's of 7.5mm; since you are talking about a 15.6" notebook, I highly doubt you'll run into any issues.
The biggest issue you'll have to worry about is how to access the drive bay and making sure you pair the drive with a proper sataII or sataIII drive. I honestly can't find the info easy enough since the specs sheet on samsung's website is very generic and not detailed enough.
PostPosted: Sat Jan 21, 2012 6:29 pm
I can already tell you need to crack it open to accomplish this.
