It is currently Mon Jan 26, 2015 7:04 am
 Post subject: Cutting Hole in Clear Case Side...
PostPosted: Sun Mar 06, 2005 4:44 pm
How would i cut a hole in my cases side? i do not own a dremmel and the case side looks like its plexiglass, or some sort of plastic. How would i cut a circle to fit a 120mm fan in the side blowin over the agp and pci slots without crackin the plastic?
PostPosted: Sun Mar 06, 2005 5:11 pm
Will Mod for Scooby Snacks!
Hole saw attachment for drill works fine.. but they can be costly..
PostPosted: Sun Mar 06, 2005 8:28 pm
A high quality hole saw will set you back quite a bit, but for making one single hole through plastic, a cheap one will work just fine. Just take your time, and make sure your pilot bit is good and secure, if it slides back into the arbor you'll end up gouging the hell out of your case.
PostPosted: Sun Mar 06, 2005 8:29 pm
If you can.. remove the side in question and clamp it down... make sure you drill or punch a pilot hole first...
7yrs+11,000 Posts
7yrs+11,000 Posts
I was at the shack today and saw a nibbler for 12 bucks.
PostPosted: Sun Mar 06, 2005 9:25 pm
Will a nibbler work on Lexan windows without cracking it?
The hole saws are nice. Just watch it and play with speeds. It may melt and bind up on ya.
The cheap way is this: Use a compass to draw the hole you want to cut out. If you don't have a compass, then you may get by with placing the fan on there and poking a fine-tip sharpie through there and trace the inside diameter of the fan. You may not get the whole circle, but you can connect the dots and make the circle.
Then, rough out the hole. You can get a cheap sanding drum in there and sand the rest out. Even with a Dremel I do this. It melts, but as long as I keep the pressure on, it keeps going through like butter.
If it still needs some fine tuning, you can do so with normal sandpaper and your skilled hand. Just eyeball it out. Then you'll need to drill 4 holes for mounting the fan. That's pretty straight forward, but a pen won't fit down in the fan's holes. You can hold the fan down onto the window and lined up with the large hole you just made, then use the holes as a drill guide. Drill straight down as any side to side will either move the fan, or widen up the holes. Once you get one in there, it may be a good idea to go ahead and drop in the hardware for that first hole, then it won't move around and the other 3 will come out right.
You also don't need an big open hole. You could get creative here and just make some fat strips like a built-in grill. You could draw these out, drill holes at each end, then take a course file and connect the dots. I've used some drill bits that'll side cut lexan...and then some that won't.
Kinda like this:
But layed out a little better than that.
PostPosted: Mon Mar 07, 2005 4:03 am
7yrs+11,000 Posts
7yrs+11,000 Posts
oohhhh :oops: i didnt notice it wasnt metal. Ignor me.
PostPosted: Mon Mar 07, 2005 4:11 am
u thought it wuz metal lol i wuz gettin confused yea but thats a good idea chumly, i think ill do that
