It is currently Tue Jan 27, 2015 12:20 pm
 Post subject: Mod Ideas for a first time Modder!
PostPosted: Sat Mar 05, 2005 8:14 am
I am a first time modder. i wanted Ideas to see wat i chould do to my case.
heres my case.take a peek
http://pg.photos.yahoo.com/ph/jasonsaob ... d5&.view=t
what should i do?:oops:
thanks for your time you guys!
jay!
PostPosted: Sat Mar 05, 2005 8:57 am
I'd rather be modding!
Its a somewhat tricket out case already. I would consider painting the drive bezels black - or finding black ones if possible.
The fan on the side could use some treatment - maybe a laser cut grill, or if you want to get your hands dirty, Maybe an Owen's style fan mod:
http://www.wizdforums.co.uk/showthread.php?t=414
http://www.mnpctech.com/Tutorials.html
http://www.mnpctech.com/mal1b.html
It really depends on how far you want to go. If you want to do a full blown mod, you need to decide on a theme. Check out the MPC gallery. You will notice that they have a theme.
Whats your theme gonna be?
Manta
 Post subject: May I suggest....
PostPosted: Sat Mar 05, 2005 9:15 am
....a side panel window on the other side of the case - the side that has the back of the motherboard tray. I did this with my Unreal case in 2002, and the results were stunning. The depth is very minimal - maybe an inch if you are lucky. I tried using cold cathodes along the window edge once it was installed, but I didn't have room against the motherboard tray - so I ended up using LEDs to light up the edges of the window. Now having a window and looking at a blank area (probably unpainted) isn't good by itself. So you want to paint the interior (I chose black), and then - here comes the best part, you paint a logo, picture, or what ever in UV sensitive paints on the backside of the motherboard tray. If you can use UV-LEDs or UV-cold cathodes at the top of the side panel, away from the motherboard tray, you might get it to fit and glow pretty bright. That's my suggestion! :wink:
 Post subject: goos stuff
PostPosted: Sat Mar 05, 2005 10:47 am
thanks for your sagestions!!!well i want my theam to be my favorite show ever evangelion.i want to incorprate some how this logo in it http://pg.photos.yahoo.com/ph/jasonsaob ... pg&.src=ph
any sagesntion in this??i was thinking of putting a hole for an nather fan on top of my case better cooling...
if u dont know anything about the series i put up some pics of it.
here http://pg.photos.yahoo.com/ph/jasonsaob ... ?.dir=4301
wat should i do??? :(
PostPosted: Sat Mar 05, 2005 12:37 pm
Before you do anything clean up those wires.
