It is currently Wed Mar 04, 2015 8:53 pm
 Post subject: How Should I Mod My Jetmaster Case?
PostPosted: Thu Mar 03, 2005 7:12 am
I was just wondering if anyone had any ideas how i can mod this case? i already have quad blue led Fans, audio reactive led bars on the top and bottom, but i need more suggestions, here's the kind of case I've got
http://www.aerocool.us/case/jetmaster/jetmaster%20bk-photo.htm
only without the ugly handle on top and the window fan is over the videocard.
PostPosted: Fri Mar 04, 2005 9:49 am
COME ON?
doesn't anyone have any ideas?!?
PostPosted: Fri Mar 04, 2005 2:08 pm
bump
sorry, I don't have any ideas, that case it pretty much already "pre-modded" (if that;s a word)
it's hard to come up with ideas for cases like that.
PostPosted: Fri Mar 04, 2005 2:47 pm
Like WR22 said it seems already modded, however the only thing I see that needs to be done is the inside. A nice paint job obviously, maybe a lighting change and obviously some creative wire managment. Other than that I'm done :)
PostPosted: Fri Mar 04, 2005 5:03 pm
it does seem well out fitted with stuff but i let this sit in my head for the day while i was at school in some very boring classes.
-Window:
--put on an applique,
--etch a design into it,
--or design and cut a peice of metal into a artistic design and liquid nial it to the window.
-Side panel:
--cut out the vent grating along the top and replace with fan covers for a neat look
--add diagonal, horizontal, or vertical strips of shiny metal that will contrast and add to the look of the paint
-Cabling:
--Turn Hard Drives around so that the cables cannot be seen
--Organize the cables neatly
-Other:
--Add LEDs, Cold Cathodes, or UV
--Paint the case, perhaps use florescent paint in the interior of the case if you use UV light.
--If you want a gruesome look, try adding fake blood by mixing red food coloring with epoxy
--Add a recessed bay in the case(perhaps a 5.25'' bay) and put the case buttons into it to hide them from sight
--Stealth your drives if you dont have a bay door
PostPosted: Fri Mar 04, 2005 7:17 pm
Smithfield*
Smithfield*
I'd say give it a really nice paintjob with some nice detailing around the 'jet' part of it.
PostPosted: Sat Mar 05, 2005 11:04 am
Thanks for all the ideas, i was thinking of some sort of metal cutout on the plexiglass.. but i don't have a pattern. plus the computer store i used to work @ bought a cnc milling machine so im going to make some custom fan grills too.
PostPosted: Sat Mar 05, 2005 5:45 pm
you dont need a pattern IMO. just freehand a design onto the metal and then cut it out with a dremel or a jigsaw. then take care to smooth it with some 80 grit on a wood block. If you have a friend who is artistic give them a general idea of a design and then just let them work... there are some cool things that come out of that. makes it really unique and one of a kind. just an idea. and i like the idea of making your own fan grilles. Good luck on the project.
PostPosted: Mon Mar 07, 2005 7:26 am
cool, so what do you mean by this:
-Side panel:
could you give me a little more detail. all this thinking is giving me a headache.
PostPosted: Mon Mar 07, 2005 5:49 pm
heh np...
above and below your side window, you have what appears to be grating for ventilation. you could expand these out to just a bit smaller than a 60mm fan grille. then drill some holes and then bolt on the grilles.
http://i2.photobucket.com/albums/y18/Sh ... titled.bmp
http://i2.photobucket.com/albums/y18/Shinekaze/fans.bmp
for the strips of metal. it'd just be long flat peices of metal, like diamond plate, cut into strips, for example, 1 inch wide. space them about 1 inch apart so the actual case shows between. then you take those strips and bolt/screw/weld/glue the strips onto the case. the diagonal with a piece of unpainted diamond plate would look a bit like black and silver metal caution tape.
