It is currently Tue Apr 21, 2015 8:38 pm
 Post subject: Mod Ideas for a first time Modder!
PostPosted: Sun Feb 27, 2005 4:57 pm
I am a first time modder. I just want some simple, basic things that I could Mod(Like beginner things). Thanks for any help in advance! :D
PostPosted: Sun Feb 27, 2005 5:01 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
case window
PostPosted: Sun Feb 27, 2005 5:09 pm
drive stealthing
PostPosted: Sun Feb 27, 2005 5:29 pm
Smithfield*
Smithfield*
Peetmoss wrote:
drive stealthing
drive stealthing is a good start, dont need any advanced tools or materials. the only thing is that its useless if you have a door. after you do something like drive stealthing then i'd try installing a blow hole, then after that a case window.
PostPosted: Sun Feb 27, 2005 6:01 pm
removing of fan grills (if restrictive),
PostPosted: Sun Feb 27, 2005 7:14 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
http://www.maximumpc.com/forum/viewtopi ... 76&start=0
PostPosted: Tue Mar 01, 2005 1:01 pm
Can you give a little more info about what drive stealthing
And what I should to do the case window???
PostPosted: Tue Mar 01, 2005 7:42 pm
Drive stealthing is just taking a spare bay cover and putting it on your optical's tray. So, when it's closed, it looks like there's nothing there.
Here's my "hard" method:
http://www.maximumpc.com/forum/viewtopic.php?t=9804
But it really doesn't go into how to do the basic stealthing. There's another tutorial I'm hunting for that someone else did. But my tut there should give you an idea on what it is.
By the side window comment, I believe they were thinking you didn't have one already. If you have a window, then you can do a quick mod by adding a fan or something creatively. It could be a simple as cutting a round hole and mounting a fan to it, or dremeling out a nice design as a grill, then mounting the fan. If you don't have a window, then make one! It's not quick and easy, but it's fairly common.
I think the cheapest mod you can do is clean up your wires. You could add all the bling in the world, and a crummy wiring job will ruin it all. A trip to Fry's and $25 got me all the stuff to do a good wiring job. You can get the same stuff for about the same with a kit from FrozenCPU. Tutorial comming soon!
PostPosted: Thu Mar 03, 2005 11:24 am
Ok thanks for explaing it in better detail!! :D
