It is currently Tue Apr 28, 2015 7:05 am
 Post subject: Product Questions
PostPosted: Sun Aug 28, 2011 12:31 pm
hey all, just have a few questions. first off does any one know if they make cpu heatsinks with led fans for socket 775 and if so anyone seen any? also does any one know if the GSKILL turbulence II memory cooler fan set have led fans and if so which color are they. cause iv looked on gskills website n it doesnt say wether it does or not. thanks in advance.
 Post subject: Re: Product Questions
PostPosted: Sun Aug 28, 2011 12:33 pm
just get a cooler you like and add the led fans ?
PostPosted: Sun Aug 28, 2011 12:44 pm
iv thought about that but i also figured that with the heat of the cpu it may cause it to melt the fan wasnt sure if they are ne different.
PostPosted: Sun Aug 28, 2011 1:51 pm
Any LED fan will do. Just make sure it moves enough air, and it's the same size.
PostPosted: Sun Aug 28, 2011 2:27 pm
kk anyone know bout the gskill memory cooler?
PostPosted: Sat Sep 24, 2011 8:58 pm
There are lots of LGA775 coolers with LED fans, like the EVGA Suoperclock for instance. You just gotta shop around :D
