It is currently Fri Mar 27, 2015 4:34 pm
 Post subject: PSU wiring question.
PostPosted: Sun Feb 20, 2005 11:05 am
I was looki9ng at my case the other day, and the only problem I see is that the psu wires are just too bulky. They are everywhere in my case. I us all the wires but not all the connectors.
Is there anyway that you can cut the wires to shorten them, kinda like you do on surround sound stereo systems, or does that mess with voltages and stuff?
Thanks
Jon
PostPosted: Sun Feb 20, 2005 2:35 pm
You probably could cut sections out, but I wouldn't recommend that course of action as soldering and splicing would increase the resistance of the wire.
Just get some zipties and some of these adhesive backed pass-throughs and yank them out of the way. Also consider getting some cable wrap or something to pull over them so they don't look as obvious.
PostPosted: Sun Feb 20, 2005 4:41 pm
Ya, just try to hid them or some thing... or make them part of the case, have it go with the "theme"
