okay i figured out the power switch problem myself, just yanked one off a old system. just gotta find a button for it now
but anyways i got my panels cut today and going to buy some plexiglass and sheet metal later this week, still wondering if you just bolt it behind the panel or you use some kinda special glue or something.. just want it to look good and not fall off lol.. plan on adding a 120mm fan to the front and 2 80mm fans to the top.. thinking of either a candy green or maybe color changing paint? any suggestions.. prolly going with green led fans if i can find them cheaper then i can buy at staples..
