It is currently Sun May 03, 2015 10:17 am
 Post subject: UH oh! Gamerfreak attemts another mod. Tabletop flush usb.
PostPosted: Sat Feb 12, 2005 8:04 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
So here is my idea. I have a 10.00 USB hub that I got from Kmart.
And what I want to do is take the guts out of it and mount it under the desk so it is flush with the desktop and I can plug my USB devices right into my desk.
Here are the guts of the hub:
I was surprised at how easily the casing just snapped right off.
Now what I was planning to do is use a PCI port cover for the "bezel"
The black lines are where I am going to cut with my dremel (excluding the squiggles on the left)
After if cut the metal I will spray paint it black, because that is the color of my desktop. Then if will solder the plate onto the sides of the sub ports.
Then I am going to drill a hole in the desk so the guts of the hub will be sticking out of underside of the desk and screw the plate onto the desk for a kind of "industrial look"
I have to do this tomorrow so if don’t wake my parents up with the drill. What do you think?
PostPosted: Sat Feb 12, 2005 8:10 pm
Dude go for it.
PostPosted: Sat Feb 12, 2005 8:36 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
uh o!! Manta is in here. Hope he takes a look at this!!!!!
PostPosted: Sat Feb 12, 2005 8:37 pm
good luck :)
PostPosted: Sat Feb 12, 2005 9:05 pm
Celeron
Celeron
Neato!
PostPosted: Sun Feb 13, 2005 12:57 am
I like the idea - and it's even posted in a legible manner :wink:
Maybe use some chrome/stainless hardware for mounting? mmm...shiny stuff
PostPosted: Sun Feb 13, 2005 3:42 am
Folding Momerator
Folding Momerator
I noticed that too :lol:
I like the idea. If I had more USB gadgets, I'd look into something like this too.
PostPosted: Sun Feb 13, 2005 7:31 am
7yrs+11,000 Posts
7yrs+11,000 Posts
I think I am going try it on a piece of wood first to see if it works out.
PostPosted: Sun Feb 13, 2005 2:27 pm
Celeron
Celeron
You jynx'd your luck. ;)
PostPosted: Mon Feb 14, 2005 6:37 pm
Smithfield*
Smithfield*
yea, i'd test it on a piece of wood before you go to the nice new desk.
PostPosted: Wed Feb 16, 2005 10:25 am
Monkey Federation (Top 10)*
Mount it over the sticker that should have been inside the desk in the first place. :)
PostPosted: Wed Feb 16, 2005 8:19 pm
sweet ass idea. i think it would be a good idea to make it more stealth and have some slider in the front. that would be slick
