It is currently Mon Jan 26, 2015 8:04 pm
 Post subject: ps adapter
PostPosted: Sat Feb 12, 2005 1:59 pm
hey guys, do u know if its possible to get a ps controller and modd it to connect it into a usb port. I was looking online and they have adapters for it but I will like to save some money by doing it myself. I know that toidiochysp was able to mod his xbox controller to use with his xbox pc mod. If anyone has any info at all let me know. Thanks.
PostPosted: Sat Feb 12, 2005 6:30 pm
I would spend the $20 and just get the kit.
PostPosted: Sat Feb 12, 2005 6:33 pm
actually I found it for 10 but I cant affort to buy at the moment.
PostPosted: Sat Feb 12, 2005 6:35 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
cut the ps2 connector off, solder the usb on (not so shure ask todischyp) and then find some drivers for it.
PostPosted: Sat Feb 12, 2005 6:59 pm
wont work, Play station controllers use a different interface. while Xbox controllers are just USB controllers and Hubs, yeah you head me right, and soon i will have a mod that will let me plug my USB flash drive into my Xbox controller :)
PostPosted: Sat Feb 12, 2005 7:03 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
o.0
PostPosted: Sat Feb 12, 2005 7:05 pm
so, acording to u guys, I will have to buy those adapter. Anyways, thanks
PostPosted: Sat Feb 12, 2005 7:37 pm
I try. And your Welcome.
PostPosted: Sat Feb 12, 2005 8:34 pm
I'd rather be modding!
Well, yes - unlike XBOX - the PS controler requires wiring up a few resistors and a circuit. Mine is on a PCB with three resistors - although 1 is for the led I suspect.
Just buy the $10 one as RS.
Manta
PostPosted: Sun Feb 13, 2005 1:00 am
The adapter kit they sell on Ebay works pretty good, I've used it a few times, gave it to my brother's best friend so he could use it for FF X!
PostPosted: Sun Feb 13, 2005 5:56 am
which one are u talking about. I just went there and there are different ones.
PostPosted: Sun Feb 13, 2005 10:22 am
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=41015&item=8168142198&rd=1
I need somebody to teach me the code.. Ahh!
BTW the above link is for an adapter, Cheap adapter!
PostPosted: Sun Feb 13, 2005 10:46 am
usb adapter
I think this is the one I bought, I got it in a bundle with 2 controllers as well
PostPosted: Sun Feb 13, 2005 12:42 pm
thanks for the link eviljeff. That one looks great. Thanks.
PostPosted: Sun Feb 13, 2005 2:21 pm
This is what I use - and RS is faster than buying online:
http://www.radioshack.com/product.asp?c ... Fid=26-304
Manta
PostPosted: Sun Feb 13, 2005 3:03 pm
Manta
That looks good. I live really close to 2 radio shacks places. I might check them out next week. Thanks everybody.
