It is currently Sat Apr 25, 2015 3:57 am
 Post subject: Project: Rage in the Machine
PostPosted: Fri May 20, 2011 5:10 am
Specs:
AMD 1090T X6
MSI 880G-E45
4GB DDR3-1333
Radeon 6850
80GB Intel SSD
700 Watt PSU
I saw this skull on eBay and knew I had to have it on a wicked new build
I chose a black Raidmax case as the canvas. I knew it needed to be plain because I would be ratically changing it and didn't want any snazzy features poking through
It came with a cheap PSU, but I'm not using it
Every evil case starts with red
A 120mm intake fan is essential when using heat trapping expanding foam
And another 120mm fan on top. Yes, it is off center on purpose
Remember this boney hand? I pulled it off my GreatSatan mod
Here's a small intake fan for the right side
I took this intake fan from my Clowned mod that my Mom never used
I'm adding mounts for the spine I took from TheGreatSatan as well
Here's where I break out the metal wire
I guess this is supposedly used to clean paint brushes, or store them, or something. To me, I see a cool grill
 Post subject: Re: Project: Rage in the Machine
PostPosted: Fri May 20, 2011 5:12 am
The arm also came from my GreatSatan mod. I originally thought this would be a terminator mod, since it's literally terminating some of my past projects
Time to finally move on to the expanding foam. I have a bit of experience with this stuff and will make it look better than ever
I had to carefully add foam to the DVD door without making it stick shut
Then I added more to the top around the top exhaust that I purposely cut off center
Then I got to painting
Next comes the skull
PostPosted: Fri May 20, 2011 5:30 pm
I used a wire mesh frame that I slid the skull over and forgot to take a picture of it. Then I filled it with tons of foam.
Here's where this mod will differ from many others. I will spend a lot of time with a small brush making it absolutely perfect
I made sure the drive worked. Guess what? It didn't. I had to tear the old one away from the foam and put this one in. Then I had to refoam and paint...
Annoying
The USB ports are actually part of a hub that is plugged into the real front panel ports. I put it on an angle because it looked better that way
PostPosted: Fri May 20, 2011 5:32 pm
Here's my motherboard
And my spare 1090T
I even had a spare Radeon 6850 reference card laying around
All the parts are in and the system does start up. The motherboard is kind of cool because it has the power button right on the PCB
I'm using an 80GB Dane Elec SSD. It says it's actually a (1st generation) Intel X25 that was made by Dane Elec. They read at about 150MBps, which is slow for an SSD, but still quicker than a mechanical drive
I dropped in 6 gigs of RAM in a 2, 1, 2, 1 configuration and the BIOS reported that I had 12 gigs installed...?
Then a changed the locations of the sticks within the channels and it still said I had 12 gigs installed
Then I pulled out the two 1GB sticks and it reported the four remaining gigs correctly
And that's where it'll stay
An eyeball arrived
I drilled out a little hole and added some foam
I tied up the veins into a screw to anchor the eye in the skull
I got out the paint brush again and made the eyeball socket bloody again
PostPosted: Fri May 20, 2011 8:35 pm
So this is what, TGS 2.0?
PostPosted: Sat May 21, 2011 6:02 pm
Kind of...it's built for the sole purpose of being displayed at the Micro Center where I work
So I got this bag of goodies in the mail. The chocolate bunny is a different kind of goodie
Now I start the assembly. The instructions are garbage so I'm going to wing it
Any ideas?
I attached the arm to the hand and started integrating foam too
Once the parts are all holding together with a little bit of epoxy, I fill in all the rest with more fleshy foam
And now to add the silver
Bloody stuff coming up next!
PostPosted: Sun May 22, 2011 11:05 pm
Where'd you order the T-800 arm kit from?
PostPosted: Tue May 24, 2011 6:32 am
Ebay. Shipped from Taaiwan
I started putting in the red flesh
I added more foam and attached the arm
Then I painted it
I have these flames from when I made El Diablo
I just had to make them red
And then I mounted them to the Video card with some epoxy, leaving the vents clear
And now it looks really hot!
PostPosted: Tue Jun 07, 2011 5:48 am
Great work dude!
You're building them so fast I almost cant keep up !
Respect !
 Post subject: Project Rage in the Machine
PostPosted: Tue Sep 27, 2011 10:31 pm
Where would a main fuse be? Near the battery? Ill have a look at earths and stuff while Im there.
Miz, Its carb, but Im not getting a spark rather than it not running right and lack of power.
PostPosted: Thu Sep 29, 2011 1:21 am
Wow GreatSatan, you really do move fast. Great work!
Coming from an old person, such as I, I would call it fascinatingly gross. It hard to look away from your intense creation. Thanks for showing us.
