It is currently Wed Mar 04, 2015 7:01 pm
 Post subject: Frank N SteinPC Epic Upgrade 2013
PostPosted: Wed Aug 28, 2013 6:08 am
I have finally finished a labor of love that has taken over 8 months of holidays, weekends, and many many nights of work. I was fortunate enough to have “Frank” to a finish point where I took him to Quakecon 2013 and entered this rig into the Case Mod contest which eventually took first place. Please check out “Frank” in the CPU Quakecon coverage in the October edition.
For your viewing pleasure, I give you Frank N SteinPC
Name: Frank N SteinPC (Upgrade 2013)
COMPONENTS:
Chassis: Mountain Mods Extended U2-UFO (Modified) & Water Barrel 24
MB: Asus ROG RE4
CPU: Intel 3930K @ 4.6Ghz daily/OC @ 5.3Ghz - all 6 cores/12 Threads
RAM: G.Skill Ripjaws Z 1866Mhz 8x4GB (32GB)/OC 2133Mhz Solid
GPU: EVGA GTX 680 4GB x3 - 3-Way SLI
S/C: Asus Phoebus Xonar 7.1
SSD1: 2x Corsair Force GT 120GB RAID 0 - Boot
SSD2: 2x Patriot Pyro SE 120GB - Programs
HDD1: Toshiba 2TB 7,200RPM 6GB SATA
DVD/BR: Asus 12x Blu Ray DVD/R/RW
PSU: LEPA G1600 1,600W PSU/1,700W PEAK - MOST SOLID/STABLE PSU EVER!
COOLING
Coolant: Primochill Performance Blood Red
Coolant Tinting: Primochill Dye pack (Used Blood Red, UV red, and Black)
Tubing: Primochill Advanced LRT Clear 3/4"OD x 1/2" ID
Fittings: Bitspower Black Sparkle finish - tons of fittings
Quick Disconnects: Bitspower Black Sparkle
RAM Blocks: Bitspower Universal RAM Cooling Blocks - modded
CPU Blocks: Watercool Heatkiller CPU v3 - modded
GPU Blocks: Watercool Hole Edition Heatkiller w/Custom Backplates - then modified
MIPS Block: EK RE4 Water Blocks Modified
Pumps: Aquacomputer VPP655 x4
Pump Dual Mod Tops: Bitspower
Pump Controller: Koolance Dual 24v Pump Controller (Front panel)
Reservoir 1: 2x Bitspower 250mm Z-tube Clear
Reservoir 2: Primochill 400mm CTR Clear w/Advanced top
Fan Controller 1: Bitfenix Recon 10w per ch/5 ch
Fan Controller 2: Bitfenix Recon 10w per ch/5 ch
Fan Controller 3: NZXT 5ch @ 30w per ch
Fans Front (Push): 9x 120x25mm SilenX Effizio EFX-12-15 15dBa 74CFM
Fans Front (Pull): 9x 120x38mm SilenX iXtrema IXP-76-18 18dBa 90CFM
Fans Rear (Push): 9x 120x25mm Bitfenix Spectre Pro Red LED 18.9dBa 56.2CFM
Fans Rear (Pull): 9x 120x25mm Enermax Magma UCMA12 18dBa 69.5CFM
Fans Top: 5x 120x25mm Xigmatech Crystal Series LED Red CLF-F1252 19dBa 61.3CFM
Radiator 1: Swiftech Performance 360
Radiator 2: HW Labs Black Ice Xtreme 360
Radiator 3: Alphacool UT60 360
Radiator 4: Watercool MORA-3 1080 (9x120)
Flow Indicator (Analog): 2x Bitspower Flow Indicator
Flow Meter: Koolance FM17N + Koolance Flow Meter Readout (Front panel)
Temp Displays: XSPC v2 Temp Readout Red (In/Out Temps - Front panel)
CUSTOM CABLES
Sleeving used was Lutro0 Customs Coreless Paracord (Imperial Red, charcoal, black).
PERPHERALS
24" Monitor: 3x Asus VW246 1920x1080 @ 60hz
27" Monitor: 1x Asus VG278HE 1920x1080 @ 144Hz
3D Control: Nvidia 3D Vision 2 kit
KB: Logitech G19
Mouse: Razer Naga Molten Edition
GP: Razer Nostromos
HP1: Razer Tiamat 7.1
HP2: Razer BlackShark Expert 2.0
Tactile: Buttkicker Gamer 2
Speakers: Klipsch HD500 5.1 Surround
Receiver: Yamaha RX-V567
Please consider the following resources when looking to do your next upgrade or build.
Primochill: http://www.primochill.com/
Lutro0 Customs: http://lutro0-customs.com/
LEPA/Enermax: http://www.lepatek.com/eng/
Bitspower: http://www.bitspower.com.tw/
Mod/Smart: http://www.frozencpu.com/brands/brand/b ... Smart.html
Bitfenix: http://www.bitfenix.com/global/en/
PerformancePCs: http://www.performance-pcs.com/catalog/index.php
