It is currently Mon Mar 30, 2015 5:12 pm
 Post subject: cold cathodes
PostPosted: Sun Jan 30, 2005 6:43 pm
Are cold cathodes safe?
I've seen pic of computers that the cold cathode light cuaght on fire.
I'm looking to pick up some sort of UV lights to make my UV reactive cable glow. (x-connect power cables and UV reative IDE cables)
Any advice?
 Post subject: chem class
PostPosted: Sun Jan 30, 2005 7:03 pm
Before I zoned out in chem. class the teacher was playing with cathode ray tubes. It was pretty sweet, anyway there perfectly safe.
Like I Always say Go for it and don’t look back.
PostPosted: Sun Jan 30, 2005 8:47 pm
the lights themselves r, it's the inverters that u have to worry about. get a good quality name brand 1, and u should be fine.
PostPosted: Sun Jan 30, 2005 11:02 pm
Here's a keepsake Xhaos :twisted:
PostPosted: Mon Jan 31, 2005 7:38 am
:twisted: nice post #! :twisted:
PostPosted: Mon Jan 31, 2005 12:45 pm
what would be a good inverter
i will have to get 4" lights, the 12" wont fit in my case
PostPosted: Mon Jan 31, 2005 12:46 pm
can i power four 4" lights off one inverter
PostPosted: Mon Jan 31, 2005 2:09 pm
wooo! thanx man. this makes #667 tho :(
and the number u can run depends on the inverter u get shooter.
PostPosted: Mon Jan 31, 2005 2:38 pm
Most only support 2 lights.
PostPosted: Tue Feb 01, 2005 1:02 am
The only way I know to judge a CCT is by relative price. The High Voltage inverters in these units are the part that fail, so if they go...the light goes. And in a big way.
Can I talk you out of using CCT's? Creatively placed LED's are so sweet IMO.
PostPosted: Tue Feb 01, 2005 4:54 pm
yeah im easily talked out of it, i just need to find away, to make my UV reactive cables(rounded IDE, x-connect) glow i need some sort of UV light, i bought a fan that was supossed to be UV, well its not, it just has blue leds in it
