It is currently Sun Apr 19, 2015 5:21 am
 Post subject: ghetto modding
PostPosted: Sun Jan 30, 2005 11:12 am
ok i got my aspire dreamer case (not the one with LEDs in front) and i was wondering what i should do about the bar in back of the case around the mobo pan (non removable) i was thinking about drilling some knoches in it so some mobo cables could go though but im not sure, my 5.25 bays prob will be backed, with 2 dvd drives, a fan controler in the third and the watts viewer/fan controler in the 4th slot so i prob not gona have alot of room in there for the extra cables
yeah the pic is bad quality, couldnt figure out how to use the camera right
previous ghetto mods.....
i got a grinder drill bit imma be able to smooth that out, plus imma take that middle peice out,
 Post subject: hmm
PostPosted: Sun Jan 30, 2005 12:24 pm
I would drill away buddy, won't hurt anything (I hope).
PostPosted: Mon Jan 31, 2005 1:34 pm
somthing i wanted to add, i had a question, can u get scrach remover for the side of a computer case, its not badly scrached just slight surface abrasion i was wondering if somthing like gs27 car scrach remover would work or somthing like that
imma have an update of my case soon
PostPosted: Mon Jan 31, 2005 1:49 pm
its worth a try
 Post subject: Go all out
PostPosted: Mon Jan 31, 2005 3:18 pm
Hey if that don't work you can break you the old rattel cans. :D
