It is currently Sat Mar 28, 2015 1:46 am
 Post subject: Power supply sleeving
PostPosted: Thu Jun 24, 2010 3:47 pm
what i want to do is sleeve my power supply, but i have some questions before i start into it. like what tools will i need, also its not modular. it has 1x 20+4 pin, 1x p4 MB, 2x sata, 8x Peripheral, 1x fdd, and 1x pcie(6pin) now i know with the molex cables you just push the pins in them but what about sata, fdd, pcie and the 20+4 pin how do i take them off also for sleeving the cables that have more then one connector on them how do i get over them like if its like this ( -------|------| cable = --- connector = | ) any suggestions/help would be great
PostPosted: Tue Jul 20, 2010 12:06 am
Team Member*
Team Member*
I did some digging around for you and found a thread that might help with your SATA question here is the link
As far as the rest goes all I can say is have patience and make sure that you take pictures and mark all of your plugs to make sure that they all go back in the correct sequence. good luck been there done that! :)
oh and don't forget the heat shrink for the ends!
