It is currently Mon May 20, 2013 3:49 am
 Post subject: adding a fan
PostPosted: Fri Jan 28, 2005 10:06 am
I have a Coolermaster Wavemaster case and I am wanting to get some more air moving in there; I am going to punch out the top USB, firwire, and audio ports and put the fan there. I was wondering if anyone had any pictures of this done with the same case.
Thanks.
PostPosted: Fri Jan 28, 2005 4:49 pm
Im sure there is because people talk about doing it all the time.
Just google it or something and Im sure youll get results.
PostPosted: Fri Jan 28, 2005 5:04 pm
It's the exact same contraption for the CM stacker's blow hole. I can take a lot of pictures for this I guess. Now, finding that fan assembly is a bit much, as I couldn't find one for sale on their site. But the Wavemaster LE comes with it as it seems.
FAQ
Quote:
Q: How do I change the I/O function panel on the top of the Wave Master?
You can easily unscrew I/O function panel and change it with a 80X80 mm casefan.
I think the mesh looks better, so try and find that on their site.
PostPosted: Sat Jan 29, 2005 4:52 am
heh, wow.
Thanks guys. :D
PostPosted: Sat Jan 29, 2005 10:57 am
Earlier versions of the Wave Master came with only the I/O Function Panel. I thought this was a poor design and was happy to see they added the 80mm fan option later. Switching them out is just a matter of 4 screws.
Click images to see larger.
Image Image
The mesh screen for the fan has recessed brackets to allow for a flush mount finish.
When I built my machine, I wanted it to be as quiet as possible. I used rubber and silicone dampeners where I could. Some are more effective than others and I changed the configuration of some of my "washers", but this gives you an idea.
If you are going to paint or powder coat, it would be a good excuse to hide those screw slugs. Preparation is the key to a quality finish.
I think the fan is much more functional and aesthetically pleasing than the function panel with a myraid of wires and cables hanging out of it.
Grump, The Mad Modder
PostPosted: Sat Jan 29, 2005 11:10 pm
wow, great.
That's awesome.
I don't even have to research this now, thanks a lot!
