It is currently Sat Mar 28, 2015 11:47 am
 Post subject: CoolerMaster HAF 932, Help with Paint.
PostPosted: Sat Apr 17, 2010 12:38 pm
Hey everyone! Last week I broke down my case & started sanding, cleaning, priming, & painting it. Almost all my metal parts are finished now I'm gonna start the plastic parts Monday pending on weather. I was wondering if anyone has painted this case & what did they use?
See I plan on cleaning plastic parts with soap & water then letting them dry & cleaning with a air nozzle & compressor. Then I plan to use a plastic primer with Rust-Oleum Sail Blue Enamel which is more directed towards wood & metal & I am curious if that Sail Blue will stick well to the plastic primer? So anyone with personal experience or a lot of painting skills & knowledge please respond. I would greatly appreciate it!
thanks
New build specs & current specs!
Zalman CNPS 9700 LED (blue)
AMD Phenom X4 9950 BE @ 3.0Ghz
Gigabyte MA790GP-DS4H
XFX HD 5770 1GB @ 960Mhz & 1445Mhz
4GBs of OCZ DDR2 1066Mhz
640GB Western Digital Caviar Blue
Logitech G15 & MX Revolution
Antec Three Hundred 5 blue LED fans
22" monitor 1650x1080 res
CoolerMaster V8
AMD Phenom II X6 1090T (stock most likely) (when it launches)
ASUS M4A89GTD PRO/USB 3.0
XFX HD 5770 (x2) & same clocks if possible
4GBs of Corsair Dominator DDR3 1600Mhz with fan
same HDD
Logitech G110 & Microsoft Side Winder x8 Mouse
HAF 932(mentioned above)
all fans being replaced with 120mm(x2 bottom & back) blue LED fans & three 200mm blue LED fans, V8 also has been replaced with a 120mm blue LED.
same monitor but next month might get the ASUS VH242H
PostPosted: Sun Apr 18, 2010 8:38 am
I've done a lot of research on case painting. If you are going to paint plastic you would want a flexible primer made for plastic and Plasti-kote makes a good 1. You can paint over this primer with whatever you want.
http://www.plastikote.com/products/Prim ... rimer.html
PostPosted: Sun Apr 18, 2010 10:18 am
You are my hero!!! I appreciate this so very much, thank you! I've been going nuts wanting everything to be perfect & finished in time for my CPU. just searched it there is one store close by that carries it so I am in luck. Thanks again.
