It is currently Mon Jan 26, 2015 3:16 pm
Has anyone ever taken an old case and modified it to a new life?
Yes 58%  58%  [ 7 ]
No 42%  42%  [ 5 ]
Uninterested 0%  0%  [ 0 ]
Total votes : 12
 Post subject: Chassis Modification
PostPosted: Sun Apr 04, 2010 2:47 pm
Team Member Top 1000
I'm debating whether to get a used ATX case then fabricating it to do everything I need it to for my next project or get a new high-end one. This wouldn't be the first instance I've modified a case by the means of cutting... etc... I find it to be a cost effective way of getting a good case without spending a fortune.
PostPosted: Sun Apr 04, 2010 4:02 pm
Million Club [PC]
Million Club [PC]
My ongoing project.
Is it cost-effective? No, I could have bought an Antec 300 with the amount of money I've spent on the mod
Is it worth the time? No, I've spent hours upon hours on the mod.
Is it easier then buying a high-end case? No way.
Is it better then a high-end case? I think the looks are on par with any high-end case, and functionally its up there with the better mATX cases, but its still just an mATX case. Like I said, just buying a 300 would have been more functional.
If you want to mod an old case to be better then a new case because you don't want to spend the money on a new case, DON'T DO IT. You'll be wasting your time. You mod a case because you want to mod it, you want to learn and use the skills it takes, and because its fun to do. If you don't enjoy the process of modding it, it's not worth it.
PostPosted: Mon Apr 05, 2010 1:37 pm
Yea, I guess you got a point there. I'll still have to modify whatever case I get to fit the liquid cooling system since it's not your average one radiator... etc... Lian Li or Cooling Master are what I have in mind.
PostPosted: Mon Apr 05, 2010 2:07 pm
After pondering a bit and seeing what both manufactures have to offer, I think I've decided to go with Lian Li. :P
