It is currently Tue Apr 21, 2015 4:27 am
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
 Post subject: Must...uncluter...cables!
PostPosted: Tue Mar 30, 2010 6:43 pm
Dah, my cable management isn't horrible, but it still sucks. I'd like some opinions on what I can do to clean all the cables up. My PSU isn't modular, so everything that I don't use, I shove in the bottom of the HDD bay.
PostPosted: Tue Mar 30, 2010 7:15 pm
Million Club - 20 Plus
What case is that?
Ted
PostPosted: Tue Mar 30, 2010 7:22 pm
Tedster wrote:
What case is that?
Ted
HAF 932
PostPosted: Tue Mar 30, 2010 7:46 pm
If you have enough room behind the mobo tray and the right hand side panel, you could cut in some holes to route the cables back there. :idea:
PostPosted: Wed Mar 31, 2010 4:06 am
You be breaking tables mah friend!
PostPosted: Wed Mar 31, 2010 9:24 am
I'm not sure that my front audio cable can be routed in the back as the port is right above the PCI-E x16 slot.
PostPosted: Wed Mar 31, 2010 10:38 am
Million Club [PC]
Million Club [PC]
you should be able to route it straight up and then through the hole you're routing the CPU power connector. That will look much cleaner.
PostPosted: Wed Mar 31, 2010 11:19 am
Oh, so route it behind the V8? I hope it can reach that far. Any sleeving that would be helpful?
PostPosted: Wed Mar 31, 2010 1:35 pm
Million Club [PC]
Million Club [PC]
Yeah I meant to the left of the V8. If the cable doesn't reach you can buy an extension from Performance-PCs
You can use split pipe tubing. I used it on my rig, worked great:
PostPosted: Wed Mar 31, 2010 2:19 pm
Where you you get your tubing? I ain't paying $7.45 shipping to $4 of stuff. :?
PostPosted: Wed Mar 31, 2010 3:30 pm
Million Club [PC]
Million Club [PC]
I got mine at Home Depot. You can also buy it at Lowe's or True Value, and basically any hardware store.
PostPosted: Wed Mar 31, 2010 3:36 pm
Where can I hide those annoying unused PSU cables?
PostPosted: Wed Mar 31, 2010 4:11 pm
The picture shows a fine solution. Nothing's broke, don't fix it. It's far from horrible as you stated.
The stuff is dusty, and showing some other concerns though. If the outside is dusty, think of the guts too. Weird 24-pin hanging out there too. Can you just cut that crap off?
PostPosted: Wed Mar 31, 2010 4:49 pm
Actually, that's an extender. It wouldn't go all the way by routing through the back. Oh well, I can wait until this one dies, then I can just get a modular one!
PostPosted: Fri Apr 02, 2010 12:59 am
I used braiding and hid the rest of the cables behind the mobo tray looks allright i think :)
PostPosted: Sat Apr 03, 2010 8:15 am
Team Member Top 250
Team Member Top 250
Make your computer look like this
PostPosted: Sat Apr 03, 2010 5:18 pm
Went to the home Depot, found absolutely nothing. Meh, looks like I'll be getting this stuff from Crazy PC. Do I need this heatshrink stuff, and if so, how do I put it on?
PostPosted: Sun Apr 04, 2010 12:27 am
If you want ot braid you cables yes you do,its pretty easy heres a link to a great guide on XS forums.
http://www.xtremesystems.org/forums/sho ... p?t=202639
PostPosted: Sun Apr 04, 2010 7:31 am
What I'm wondering is do I really need to remove the connectors to sleeve? The guides refer to Molex connector, which are huge, but mine aren't that huge.
PostPosted: Sun Apr 04, 2010 7:39 am
Million Club [PC]
Million Club [PC]
yeah. It's impossible to get the sleeve on without removing the connector, unfortunately. Unless you use a huge sleeve, which looks like crap.
