It is currently Fri Jan 30, 2015 4:08 pm
 Post subject: Water Cooling is SO 20th century!
PostPosted: Sat Mar 27, 2010 5:55 am
Try Minreal oil bath instead!
http://www.instructables.com/id/Mineral-Oil-Submerged-PC/step1/Gathering-the-Materials/
..Gonzo
PostPosted: Sat Mar 27, 2010 6:22 am
Mr. Late Night
Mr. Late Night
Not a bad idea, but the way he built it is pretty primitive. It also has no way for the mineral oil to be cooled. The oil will absorb heat and now it has no way of dissipating it. There's a guy that posted on the Anandtech forums on how he built his Mineral Oil PC. It took some trial & error along with a large amount of time and custom machining the entire case. The oil is cooled by being pulled through a radiator at the bottom of the case which is blown across by multiple case fans. If you're interested in reading the link is here: http://forums.anandtech.com/showthread.php?t=2060807
PostPosted: Sat Mar 27, 2010 6:33 am
Million Club - 20 Plus
this has been out for a while.
There was a thread on this a while ago, but I don't remember when it was exactly.
Ted
PostPosted: Sat Mar 27, 2010 9:56 am
Team Creamsicles
Team Creamsicles
There was a maximumpc rig of the month a few years ago which was submerged in oil as well.
PostPosted: Sun Mar 28, 2010 11:09 am
http://www.hardcorecomputer.com/
This was on MPC a while back, the true standard for oil cooling.
PostPosted: Mon Mar 29, 2010 1:43 pm
Monkey Federation (Top 10)*
Good Christ guys. This is YEARS old. lol Search Mineral Oil Computer. There are a few threads about it. Some I made myself.
PostPosted: Sun Apr 04, 2010 3:08 pm
Team Member Top 1000
I've debated doing something like that until I learned it isn't all it's cracked up to be. A guy's CPU was overheating even with a cooled current (flowing) submersion setup. I can't remember all the specifics why he was having that issue, but pinpoint or traditional liquid cooling is a proven effective way to cool computer hardware. Submersion has only been done by one manufacturing company combined with traditional liquid cooling, yet the specs show it's really not a dramatic difference in performance. A good liquid cooling setup with a high cfm equal intake and exhaust chassis/system fans will result in a high stable overclock. 4.5+ GHz is feasible with the right setup. Any higher you're going need Liquid Nitrogen or Helium. You might as well get two Xeon CPUs if you want more processing power. Thermal Paste can make a big difference too. It was proven by Benchmark when they tested 80 different pastes... etc... Overall a custom cooling system should be well thought out before jumping into the nitty gritty. :P
