It is currently Fri Apr 17, 2015 8:26 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
 Post subject: The official low-budget modding PC
PostPosted: Fri Jan 21, 2005 3:52 pm
Since the idea came up of modding my computer I am giving myself a $100 budget to mod my PC :lol: . Some before pictures:
Those are pre-modded pictures of my PC. This is the list of steps to mod my PC with the $100 budget:
1. Organize wiring.
2. Buy wire sleeves
3. Buy rounded cables
4. Have a blow hole added to the top
5. ??????
PostPosted: Fri Jan 21, 2005 3:56 pm
Monkey Federation (Top 10)*
Okay that's $10. What do you want to to with the other 90? lol
NEON!
PostPosted: Fri Jan 21, 2005 4:00 pm
havent decided yet :?
here is my PC re-wired:
Also have this random fan laying around... What should I do with it:
AHHH MY SOCK IS IN THE PICTURE!!!
PostPosted: Fri Jan 21, 2005 4:03 pm
There's your reason for the blow hole!! WEEEEEEEEEEEE!!!!!!!!
Definitely go out and get some cable wrap/ wire sleeve though. That should be everyone's first mod after adding a window. :)
PostPosted: Fri Jan 21, 2005 4:47 pm
find a way to add that dual fan underneath your GPU. more cooling, more overclocking. mod. add some CCFLs dude. Uv is great if you get UV reactive cable sleeving. just some ideas...
PostPosted: Fri Jan 21, 2005 5:45 pm
you know what big socks mean...
PostPosted: Fri Jan 21, 2005 7:42 pm
I'd rather be modding!
Big Shoes :)
Manta
PostPosted: Fri Jan 21, 2005 7:46 pm
MantaBase wrote:
Big Shoes :)
Manta
You know what big shoes mean? :lol:
PostPosted: Fri Jan 21, 2005 10:03 pm
for not using wire wrap your wireing job look pretty good, might i suggest a image etched into the side window
PostPosted: Sat Jan 22, 2005 3:35 am
Folding Momerator
Folding Momerator
Do something with those drives- either paint them all silver or black, something.
PostPosted: Sat Jan 22, 2005 1:29 pm
The best place for my 100th post... YAY!!
PostPosted: Sat Jan 22, 2005 3:56 pm
Celeron
Celeron
Isn't that a HDD cooler? I don't know, the side mounts throw me off.
PostPosted: Sat Jan 22, 2005 4:02 pm
yes it is
PostPosted: Sat Jan 22, 2005 5:49 pm
Celeron
Celeron
Well...uh...then...use it for your hard drive if you feel like it.
PostPosted: Sat Jan 22, 2005 6:08 pm
thats a good idea, i just used black drives(i want a blue/black/silver theme)
PostPosted: Sat Jan 22, 2005 6:13 pm
Well my case cant support it.. :cry:
PostPosted: Sat Jan 22, 2005 6:18 pm
My spending part is on hold since I bought Media Center 2005 things. I can find a way to put that HDD fan somewhere though..
PostPosted: Sun Jan 23, 2005 2:38 pm
Your wiring job can be much improved, I know because I also have the SuperLanboy and it has many cable management options available for you. I'll post back with some pics of mine to give you ideas when I can host them. As for the extra fan, I ziptied another blue 80mm fan to the inside of the HDD cage to suck the air from the front 120mm fan across the HDDs and blow it into the case faster/further, which, with no wires in the way, makes a very effective cooling strategy. I think the blowhole in the top of the case is not the greatest idea because it seems like it would negate theflow of air to the exhaust fan from the front intake because they would be colliding, but thats just IMO.
PostPosted: Sun Jan 23, 2005 3:50 pm
I found a place to install that HD fan... I just need to cut and put a grill so It can blow out hot air.
PostPosted: Mon Jan 24, 2005 2:05 pm
Ok, I stuck the pics on an old Geocities account from a skule site, I apologize for the JPEG artifacting, I had to compress them a fair bit to make tham suitable for my dial up connection.
This one shows the HDDs turned backwards, and the outtake fan wire strapped in. I also tiwsted the wires for the CPU and Northbridge HSF 'cause it looks neat
Same as before almost, only a nicer angle. See the 80mm fan ziptied there?
This shows how you can manage the cables at the back of the drive bays, note the adhesive backed pass throughs for the zip ties, get some because they are a lifesaver for cable management.
Well, I hope that gave you some ideas, theres lots of places to hide stuff so you should be able to have the inside clean easily! :)
