It is currently Mon Jan 26, 2015 5:45 am
 Post subject: CM extra fan case mod
PostPosted: Mon Dec 21, 2009 1:04 am
hi guys
alright this gonna be my intro to modding ok
ive got a CM cavlier case now i wanna add a fan to the side of the case.
i wanna add the largest fan possible to the case. now the problem is ive a tall tower cooler ocz vendetta 2. im almost certain the a fan not gonna fit between the cooler and the door. question how do u find out plan for mods. and do we find out the distance between the drive bays and the cooler and where the distance is?
PostPosted: Mon Dec 21, 2009 3:52 am
Million Club - 5 Plus
no real set in stone ways. measuring always works, I usually measure from the top and rear panels. easy reference points.
you can also just temporarily tape it to the side panel and see if it clears.
PostPosted: Mon Dec 21, 2009 6:34 am
Million Club [PC]
Million Club [PC]
that's the best way to do it. Quick and dirty.
