It is currently Wed May 22, 2013 9:07 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: Copper anyone?
PostPosted: Fri Jan 21, 2005 7:02 pm
Bigal wrote:
Hey, I have a few fan grills that were made out of copper. You could get a sheet of copper and do some Dremel cutting. It's soft and looks nice when polished. Coat it to prevent oxidations though. :P
good idea but copper would not go well with my pc
 Post subject: They would if you...
PostPosted: Fri Jan 21, 2005 7:17 pm
...paint or powdercoat them. They could be plastic too. How about plastic with embeded LEDs? They might take on a translucent-type glow.
PostPosted: Sat Jan 22, 2005 1:55 pm
the fan behing it will be led(blue) and i picked up a piece of aluminum to day now i just need a pattern and a dremel
PostPosted: Sat Jan 22, 2005 10:44 pm
Just a word on aluminum too...it's not just soft, it's SOFT. It'll load up your media, so becareful of this as it'll unbalance the disc (if you're cutting it) and will almost always shatter. If it starts to rumble, give it a quick change. The discs come in that tube, and there's about 25 in there...so use 'em up.
I like using the sanding drum to eat it away if possible instead of cutting with the disc. But, sometimes it just cuts like butter. Must be the type of Alloy they use that makes the difference.
