It is currently Sun Apr 26, 2015 4:49 pm
 Post subject: need help with new hdd format
PostPosted: Sun Jul 18, 2004 7:03 am
i have an older pc that i want to set up as a simple file server sharing video and audio files accros my network My setup is as follows,
Windows Me
p3 800mhz
256 mb of ram
asus cusl2 motherboard
liteon 48x24x48 cdrw
generic floppy
Maxtor 45gbyte hdd drive set to primary ide channel
i added a brand new western digital special edition 80 gig hdd to the system on the secondary ide channel, slaved to liteon drive which is set as master
Bios sees the drive, and it is showing up in the device manager of Win Me under the disk drive section as ide type 80 but no dirve letter is being assigned.
Booting to dos, again i cannot find the drive to format it. How can I get this drive formated so I can use it?
tia
PostPosted: Sun Jul 18, 2004 7:16 am
i think its better to slave your WD hdd with your matrox hdd. do that and see if you get a drive letter assign.
PostPosted: Sun Jul 18, 2004 8:25 am
Astro lube 2 the MAX!
do keymakers suggetion. then do the following
After doing that, get your boot disk, gointo DOS, fdisk your drive, setting up your partitions. Then do the format X: (replacing X with whatever drive letter it assigns.)
PostPosted: Sun Jul 18, 2004 9:02 am
run fdisk to make sure it is partitioned correctly. a format won't work if the drive is not partitioned.
PostPosted: Sun Jul 18, 2004 9:07 am
tanks all, ill try that in a little bit, wallpapering today hehehe :)
PostPosted: Sun Jul 18, 2004 9:40 am
one other issue now, there is no legend for the maxtor master/slave pin configuration on the drive. below is the default config
IDE Connector : : : . : 4 pin power connector
jumpers
pin 1 and 6 have a jumper, along with pin 2 and 3. there is no pin 4
do i need to configure this differently with a slave hdd present?
PostPosted: Sun Jul 18, 2004 9:51 am
ok, found the jumper configs on there web site....
PostPosted: Sun Jul 18, 2004 11:27 am
ok, update......made the requested changes. did not resolve the issue. cannot find drive from boot disk or in Windows. no drive letter. now ident as type 47 drive in device manager, same as primary master drive. any more suggestions?
PostPosted: Mon Jul 19, 2004 12:34 pm
got it formated via fdisk.....i didnt understand the scope of fdisk. works good, i made more out of it this simple issue than should have been :oops:
again thx all
PostPosted: Mon Jul 19, 2004 4:33 pm
again thx all
fdisk partitions the drive, not formats it. you still need to format the drive, which you shold be able to do in windows.
