It is currently Sun Feb 01, 2015 6:50 am
 Post subject: help the novice
PostPosted: Tue Jul 13, 2004 11:57 am
can anyone tell me how to change default explorer?
i want to change my default from internet explorer to opera or mozzila exploer :oops:
please tell me your :idea:
PostPosted: Tue Jul 13, 2004 12:02 pm
well, it depends on which one you want to be your default browser...
I use firefox 0.9.2 and it has the option to check for you when it is first installed. After that you can go to the menu of
Tools >> Options... >> General >> Default Browser and hit "check now"
it will tell you if it is or isn't. If it is not, it will ask you if you want to change it to that browser
Again, this is for Firefox, which is made by Mozilla, so it would probably be different for Opera.
Good luck
PostPosted: Tue Jul 13, 2004 12:36 pm
there is also a "Set Program Access and Defaults" button in your Add/Remove Programs box, although it doesn't have a whole lot of options.
PostPosted: Wed Jul 14, 2004 5:22 pm
Open Internet Explorer, go to Tools and choose Internet Options, Programs, under "reset web settings" there is a box, put a check in it and hit apply then follow instructions.
PostPosted: Wed Jul 14, 2004 8:48 pm
hey novice, stick to mozilla. forget IE
PostPosted: Thu Jul 15, 2004 10:53 am
hey thanks for all your helpful tips....i ...uh shall try them
opera is a very decent browser,hav you ever try downloading their skins?
man, i hav to say its jus too sexy!so i want to make opera my default browser.
the new problem is that i cant even open IE anymore,because it crashes every single time i open it.i even try hitting my head with a broom and kicking my wall just fun(mom said it would help)
so wuts the deal?
PostPosted: Fri Jul 30, 2004 8:20 am
The deal is, IE Explorer is so full of bugs, loopholes, backdoors ro what-have-you, that it really isn't worth the hassle. You go to their site to get new patches, and half the time the patches make your problems worse.
Don't know about Opera, I use Firefox. Stick with opera if you want. Try Firefox though.
