| Team Member |
Joined: Mon Jun 28, 2004 12:56 am Posts: 1076 Location: Powder Springs, GA
the way i delete files that wont let me delete them even after a reboot is this:
1. Hit Ctrl+Alt+Del to go to Task Manager
2. Go to Processes tab
3. Select explorer.exe and then the End Process button
4. Go to the Applications tab on Task Manager
5. Click the New Task button
6. Click the Browse button
7. Select All Files in the pull down menu
8. Browse to the file(s) that's giving you a problem
9. Select it and delete it
10. Click the cancel button
11. Click the New Task button again
12. Type "explorer" without the quotes in the box
13. Click the OK button
It's generally best to restart after this, cuz a lot of the stuff that was running in the taskbar will no longer have icons, but it's not necessary. I only know this works with XP Pro, but it should work with XP Home and 2K also.
