It is currently Tue Jun 18, 2013 3:19 pm
 Post subject: Unable to get online
PostPosted: Sun Jul 11, 2004 4:19 pm
I am unable to get on the web and check email. I keep getting a TCP/IP error. I tried to uninstall TCP/IP but get a Network Connections Error stating that the component cannot be uninstalled because they are required by other components:
Simple TCP/IP Services
Print Services for Unix.
I am on Win 2000 Pro. I can ping the internal IP but nowhere else in cmd.
Any suggestions?
PostPosted: Sun Jul 11, 2004 6:09 pm
could be a nic card gone bad. if you have another nic card, try using a spare nic. more info about your system and network would be really great too.
 Post subject: Re: Unable to get online
PostPosted: Sun Jul 11, 2004 6:16 pm
Any suggestions?
Are you sure it's the NIC card? Are you connected to a router? Are you in the right connection slots? Are you set up to get on the net? What type of network is it? etc etc.
PostPosted: Sun Jul 11, 2004 6:23 pm
I have a cable modem running to a router. I have 2 other pc's that are on a wireless LAN. The problem is that I was able to get online for a while. After getting rid of my adware the pc is running at 100% processor and I am not sure what is running. Also, my peorsonal firewall won't run.
PostPosted: Sun Jul 11, 2004 7:01 pm
Just to add, before I reboot I get an End Program prompt and the name is MessageBouncer. I did a search but didn't find this program
PostPosted: Mon Jul 12, 2004 12:03 pm
Hello Cheeba,
I did a Google search and came up with this piece of info from another forum:
"Boot up, start hunting for Messagebouncer - ends up it's in a Real One .dll
- goodbye Real."
So I would get rid of Real One and see if your problem goes away.
PostPosted: Tue Jul 13, 2004 6:33 am
Thanks. It did. However, I believe that it is a winsock issue that is related to Ad-aware. I am trying to figure out how to resolve the changes it made.
PostPosted: Tue Jul 13, 2004 8:02 am
do a ipconfig /all and post the results here.
I'm going to have a hard time believing that this is anything to do with ad-aware and everything to do with how you're talking with the rest of thw world in reguards to how things are configured, either at your TCP settings of within IE.
PostPosted: Wed Jul 14, 2004 8:23 am
http://www.dslreports.com/forum/remark,9548698~mode=flat
