It is currently Sun May 19, 2013 2:40 pm
 Post subject: problems with windows files/settings transfer wizard
PostPosted: Sat Jul 10, 2004 10:35 pm
i tried using windows files/setting transfer wizard found in the acc/sys tools/ and had my settings and files sent over to another computer on my network
the initial plan was to reinstall windows as the computer became unstable
i reloaded xp and now i can't get the files back onto the computer it says not enough disk space but there was <4 gigs of data
so i tried running the file/setting wizard on another computer and transfer the files there but i get the same msg.
the files are several years worth of pic/music/word docs so i really need to have access to them
is there a third party app that will let me extract the file manually like a zip folder
the file type extension is *.dat
its in a folder called usmt2.unc and the files in the folder are img00001.dat and img00002.dat and a status file
:cry: i really want my files
 Post subject: found the file i just don't have it
PostPosted: Sun Jul 11, 2004 7:42 pm
after doing a little research i found out microsoft does indeed have an app that will manually let me extract the *.dat files
the app is called fastconv but is unavailbe for public download and must be requested via calling microsoft
I refuse to pay microsoft $35 for a file i should be able to have acess to
does anyone have a link or the file fastconv not to be with a image converter which i've found online
if you do have the file plz send to dayvideg@excite.com
PostPosted: Mon Jul 12, 2004 6:51 am
i'm confused. you're just looking to transfer files from one computer to another?
why not just copy and paste if you got them networked? i've never ever used that File Transfer wizard.
 Post subject: in theory
PostPosted: Mon Jul 12, 2004 10:54 am
file settings transfer wizard is supposed to be able to make the move from one computer to another very easy leaving all of you settings intact as well as moving all of you documents but well its microsoft so crap never works like its supposed to
Users browsing this forum: thejustchad and 3 guests
