It is currently Tue Apr 21, 2015 1:14 pm
 Post subject: Recent "critical update" for XP causing constant c
PostPosted: Sat Jul 10, 2004 5:41 pm
My system started crashing CONSTANTLY, seemingly out of the blue. I thought it was my videocard, after a lot of playing around with my main machine and another computer it appears 99% certain that the problem stems from a recent Windows XP "critical update". See the thread I started titled "Is my GeForce 5700 Ultra dying or...????" To make a long story short, everything seems just fine until I install recent critical updates. Then, it's non-stop crashing.
Anyone know of a problem with any recent critical updates for XP??
System specs:
P4 2.4 GHz 533 bus
Intel D850EMV2 mobo
512mb RDRAM (2 x 256 PC1066)
GeForce 5700 Ultra 128mb
Western Digital J1200 120mb HD
Windows XP Home
PostPosted: Sat Jul 10, 2004 6:04 pm
what critical update?
the SP2 RC2 update?
if so, that is the reason
you might be able to uninstall the update
PostPosted: Sat Jul 10, 2004 6:27 pm
SP2 RC2 isnt a critical update.
PostPosted: Sat Jul 10, 2004 6:28 pm
If you have system restore enabled, try restoring to a restore point that was created before you installed the patches.
PostPosted: Sat Jul 10, 2004 8:44 pm
It's not the updates. It started doing it again BEFORE installing the critical updates this time. I suspect motherboard. I have 4 RIMM slots and I took my 2 RIMMs and put them in the other 2 slots. Things worked fine for awhile and everything seemed normal, even on the old hard drive. Then it started happening again.
I would think this would suggest motherboard. I swear, I have had more problems with mobos over the years than any 5 people I know added together.
PostPosted: Sun Jul 11, 2004 12:53 am
I forgot if you've done this...but have you done a full virus and Trojan horse scan? Fleeting hope here...I'm running out of ideas.
 Post subject: quick fix
PostPosted: Mon Jul 19, 2004 4:47 pm
Use System Restore and go back to right before the update. If all is well contact Microsoft tech support or check MS knowledgebase for remedy.
