It is currently Tue Apr 28, 2015 12:53 pm
 Post subject: Why are MPGs renamed as "MPEG" in IE? Weird file s
PostPosted: Fri Jul 16, 2004 3:59 pm
Hi,
For awhile now I've had this problem - it's more of an annoyance, actually, but I'd like to get to the bottom of it. You see, what's been happening is that whenever I go to save a movie in IE, an MPEG movie , for example named:
catmovie.mpg
It ALWAYS renames it automatically so that the file is saved as:
catmovie.mpeg
Instead. Why is this, and can I fix this? It's just bugging me.
PostPosted: Fri Jul 16, 2004 5:02 pm
Well, you can just rename it mpg, but I don't have a real answer for you.
 Post subject: Re: Why are MPGs renamed as "MPEG" in IE? Weird fi
PostPosted: Fri Jul 16, 2004 6:08 pm
Bitchin' Fast 3D Z8000*
regalia wrote:
Hi,
catmovie.mpg
catmovie.mpeg
FYI, MPEG stands for Motion Pictures Expert Group
http://en.wikipedia.org/wiki/Mpeg
Just use the cli to rename the files.....
rename *.mpeg *.mpg
Try this in a seperate directory on some backup copies first.
PostPosted: Fri Jul 16, 2004 8:48 pm
Thanks a lot, the auto rename will help me with a lot of files.
But I'm wondering still why Internet Explorer is messing with MPG files from the net by adding that E in there! Other browsers don't seem to do it, so what in blazes is going on?
PostPosted: Fri Jul 16, 2004 8:59 pm
Astro lube 2 the MAX!
regalia wrote:
Hi,
catmovie.mpg
catmovie.mpeg
Hmm maybe it is just a universal thing. I don't really know why. Maybe they couldn't decide which file extension to use and somewhere in the line both got used but nobody cared enough?
PostPosted: Fri Jul 16, 2004 11:38 pm
Some things cannot be explained - IE is just that whack. ;)
PostPosted: Sat Jul 17, 2004 8:14 pm
true dat gadget...
PostPosted: Sun Jul 18, 2004 7:30 pm
I think its like .jpeg vs .jpg ... no difference really, just one less letter.
But no idea why it would change the file extension.
PostPosted: Sun Jul 18, 2004 7:51 pm
probably the IE standard for no real reason
