ponchotires wrote:
My problem is that my computer was infected by a virus (well 14 of them) know I cannot boot my Pc every time i try to boot it restarts and tells me that windows did not load correctly and it sends me to a menu to load windows in safe mode and others but i have tried all options and it keeps doing the same thing my Pc is a Hp Pavilion 7955, I cannot even acces my bios settings in order to change my boot sequence and just try to reinstall windows using my recovery disk that comes with my Pc, I hook up the drive as a SLave in an other Pc and thats the only way I have access to it, I have ran a antivirus program on it and erradicated the viruses, so i when back and hook up my drive again to my HP but the same problem persists, so i tried by hooking an other drive that i have and tried to reinstall windows on it but at boot time the pc say it cannot find NTLDR (i wonder what that means) and cannot continue with the installation, the windows version is windows XP Home Edition , is there a way i can acces my registry or my boot sequence when i hook up my drive to my other pc when i set it up as a slave so i can reinstall boot sequence that work or what do u suggest i can do, please help me.
I would do what keymaker says but us the command chkdsk /r
