It is currently Fri Jan 30, 2015 3:39 pm
 Post subject: bad display problems
PostPosted: Fri Jul 02, 2004 4:24 pm
hi everyone,
well, today i started up my computer and for no apparent reason my display has shifted up about 2 inches and is tilted down to the right about 10 degrees. I tried to adjust the monitor with the buttons on the front pannel and it won't let me. i get an osd lock message each time i press a button. i looked up in the manual to see if there was a way to disable this, and following the instructions (hold [1] and hold up arrow for 10 seconds) doesn't do anything. I though this might be a video card problem, so i took a screenshot of my desktop, and it came out normal. i have a viewsonic g90f.
i appreciate any ideas you might have
PostPosted: Fri Jul 02, 2004 4:36 pm
may be time for a new monitor
i had that problem too. i couldnt figure out how to fix it
PostPosted: Fri Jul 02, 2004 4:55 pm
i sure hope it's not time for a new monitor, barely had it a year heh 8)
PostPosted: Fri Jul 02, 2004 4:58 pm
it under warrenty then?
PostPosted: Fri Jul 02, 2004 5:10 pm
yea, i got a 3 year warranty... might have to use it :?
PostPosted: Fri Jul 02, 2004 10:30 pm
Any large magnets nearby? :)
Seriously, a speaker too close?
Just a shot, before you resort to the warranty.
 Post subject: Re: bad display problems
PostPosted: Sat Jul 03, 2004 2:01 am
Chief Surgeon
Chief Surgeon
-Snake- wrote:
hi everyone,
Snake, this might sound weird, but it's worked occasionally in the past:
1. Unplug Power Cord from the back of the monitor.
2. Press and hold the power button on the monitor for 10-15 seconds.
3. Plug the Power Cord back into the monitor
4. Restart the monitor and test.
There should be a Degaussing Button (possibly with an icon which looks like a magnet) on the front. Try using that to see if it will reset it.
Have you tried the monitor on another system, just to ensure the same thing happens?
SC64
 Post subject: Monitor issue
PostPosted: Sat Jul 03, 2004 6:28 am
I had a similar problem once, it turned out to be my monitor and a very expensive fix since they only wanted to give me a small portion of the $$$ back.
I would try a new video card to test it rather than waist all sorts of driver updates. Or if you have a spare monitor just to test with that would work too
PostPosted: Sat Jul 03, 2004 10:35 am
I'm gonna hook this monitor up to my old pc and see if it does the same thing. no magnets or speakers nearby. i just tried doing what you said superchip but to no avail. i also tried it on a new video card (x800 pro woot!) and that didn't help either. i'll prolly give viewsonic a call today and see what they say...
are viewsonics known to do this? i've not heard of this before now :?
EDIT: well, i hooked up this monitor to my old pc and got the exact same problem. i know for sure that it's the monitor now
 Post subject: Its the monitor
PostPosted: Wed Jul 07, 2004 8:58 am
If you tried more than 1 video card then its def the monitor no need to test further. I rached my brain and did the same thing on my troubles
PostPosted: Wed Jul 07, 2004 12:45 pm
lately it's started to get worse lol. i eventually got it off of osd lock, but now none of the buttons are functional. when i hit a button, about 10 seconds later the screen turns off and comes back on. weird. i contacted viewsonic and they said that was pretty fubar'd and to send it back to get fixed/replaced
thx all for the help
PostPosted: Wed Jul 07, 2004 6:03 pm
Folding Master (Top-ranked)
I wouldn't want to pay your shipping costs. Maybe there is an outfit doing viewsonic repairs in your arrea. Write to viewsonic support.
PostPosted: Wed Jul 07, 2004 6:10 pm
yea i know, shipping for a monitor is insane. i would definitely (note that it is spelled correctly) rather take it somewhere by hand than ship it...
