It is currently Tue Jan 27, 2015 4:11 pm
 Post subject: Virus of the crap...
PostPosted: Tue Jul 06, 2004 10:00 pm
Ok, this is the virus I'm pretty sure my little sister has:
http://securityresponse.symantec.com/av ... .worm.html
Basically it doesn't let you open any windows task things like regedit, taskmanager, gpedit.msc, msconfig, etc. etc.
I have attempted the fix they list (safe-mode startup, run virus scanner in safemode) but AVG 6.0 will NOT run in safe mode. Is this normal? Will I have to have her buy NAV or something?
The virus is incredibly annoying especially since she is a complete dipshit and downloads all sorts of garbage from the net, so it's hard to eliminate this stuff with no access to regedit, task manager, gpedit, etc.
Anyone have any suggestions for me? muchas gracias de la cabra
PostPosted: Tue Jul 06, 2004 10:57 pm
Contributing Writer
Contributing Writer
Can you have her install the trial version of NAV and uninstall once the infection is cleaned?
PostPosted: Wed Jul 07, 2004 10:04 am
there are trial versions of NAV and McAffe somewhere on the net.
i would start with those...
AVG doesnt run in safe mode? im supprized. they should update that
PostPosted: Wed Jul 07, 2004 10:25 am
No need to run NAV. Just search for an online virus scanner. (i didnt see you mention anyhting about not having net access. Online virus scanners are good because they can still be run when viruses disable yours. I think trend micro has a good online AV. I googled and found this.
http://housecall.trendmicro.com/
Try giving this a shot if you can. Hope this helps.
JB
PostPosted: Wed Jul 07, 2004 11:55 am
I can try... I was hoping I could get it done before I left CA for Tech again.
I was thinking about gettin one o'dems. Thanks
PostPosted: Wed Jul 07, 2004 11:56 am
I think so too... it would run in windows normal boot, though, so it wasn't the virus
*shrug*
PostPosted: Wed Jul 07, 2004 11:57 am
JB
Thanks, I saw this one when I was googling for an answer, but I couldn't get it to run.
PostPosted: Wed Jul 07, 2004 1:42 pm
[quote="ShiftyEyedGoat"][quote="jbrock31"]No need to run NAV. Just search for an online virus scanner. (i didnt see you mention anyhting about not having net access. Online virus scanners are good because they can still be run when viruses disable yours. I think trend micro has a good online AV. I googled and found this.
JB[/quote]
Thanks, I saw this one when I was googling for an answer, but I couldn't get it to run.[/quote]
This is because the way safe mode works is it only loads the required windows drivers to get the computer to boot. This is designed to prevent any startup programs that are causing problems on a system from running for troubleshooting purposes.
This is why no av program will run normally. If you can find one that will run from the command prompt and run in dos mode, it will run. I doubt you could get anything online to work because it does not run ActiveX or any other net technology in safe mode.
Does SARC's website give removal programs. You might try to see if there is a separate removal program available.
PostPosted: Thu Jul 08, 2004 6:30 am
I really like the Panda Antivirus online scanner, it's found and fixed viruses for me that NAV and Mcafee could only quarantine at best.
Try this link
http://www.pandasoftware.com/activescan ... ncipal.htm
PostPosted: Thu Jul 08, 2004 10:32 pm
copy regedit to the desktop
rename it reg.exe and run it
go to the HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run
RunOnce
RunServices
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
look for the it there (it will be something to do with microsoft (microsoft does not use this to start anything for the os))
reboot in to safe mode
and delete that little trickster
PostPosted: Fri Jul 09, 2004 2:24 pm
Go to this site with your sisters PC and run this software....it works!
Also get Spybot and Ad Aware and run them after you update them. You can get them here:
http://www.majorgeeks.com/
On the left, click on spyware tools and you will find the above software there.
It works fine and everything I linked to is free :)
