It is currently Mon May 04, 2015 3:03 am
 Post subject: Need help with Zone Alarm and downloads
PostPosted: Fri Sep 03, 2004 10:19 pm
ALMOST BANNED
ALMOST BANNED
Seems like I have to shutdown ZoneAlarm to download anything and I can't seem to find exactly what I need to tweak in it's settings so I can download things. Where do I need to look?
PostPosted: Fri Sep 03, 2004 10:21 pm
check your program control to make sure the program/s has access rights, and maybe you should run high/medium for the zone security if your running high high.
PostPosted: Fri Sep 03, 2004 11:46 pm
i used to use zonealarm and i think the problem could be in the advance part of the program control. im tyring to picture it in my head but is very vague since i havent used zonealarm in a while. enable something that deals with incoming/outgoing DNS/DHCP. i had to enable this in order for me to download stuff.
 Post subject: Re: Need help with Zone Alarm and downloads
PostPosted: Sat Sep 04, 2004 8:48 am
What version of ZA are you using. I have heard lots of people talking not only in here but other places with lots of bugs in ZA 5.
PostPosted: Sat Sep 04, 2004 11:33 pm
The new free version is glitchy. You could try reinstalling zonealarm not before uninstalling it and deleting and residual files. I have see zonealarm do wierd stuff before like break internet unless it was turned off, etc etc. Also i took a look at the latest free version and it seemed pretty strange to me. Maybe you could ask around for a slightly older version.
PostPosted: Sun Sep 05, 2004 7:32 am
Sailorman
Sailorman
The very latest version 5.1.011 seems to be fine on my machine with SP2. Earlier versions don't play well with SP2.
PostPosted: Sun Sep 05, 2004 9:53 am
ALMOST BANNED
ALMOST BANNED
Well, just for future reference, I found out what was causing my problem. I would go onto websites/forums where posters could post pictures and they wouldn't be there. Then I disabled each function in ZA until I could see them. I had the banner ad blocking set to the highest. Once I reduced it to medium, I could view people's pictures. I returned ZA to all of the settings I turned off and with ad blocking set to medium, it still worked.
