It is currently Sun Apr 19, 2015 8:12 am
 Post subject: HELP!!!!!!! I HAVE 475 GIGS NOT SHOWING!!!!!
PostPosted: Fri Sep 03, 2004 1:15 pm
Ive been sitting here and waiting for an answer on why 3 out of 4 of my drives hooled up to my mobo are responding in bios, but not in windows... and that is after drivers have been put in
PostPosted: Fri Sep 03, 2004 1:20 pm
King of All Voodoo2 Cards
What's it saying over in Disk Management?
PostPosted: Fri Sep 03, 2004 1:24 pm
Under system information from the start menu... the drives are detected, but i cant use them...
PostPosted: Fri Sep 03, 2004 1:28 pm
Did you double check all of the obvious possiblites? Make sure they are plugged in right
PostPosted: Fri Sep 03, 2004 1:29 pm
Im not dumb, its being detected by system information device manager and etc.....BUT it is not in my computer, and i cant use it....
PostPosted: Fri Sep 03, 2004 1:34 pm
But did you try Disk Management?
Start --> Programs --> Administrative Tools --> Computer Management --> Disk Management.
The drives probably just need to be initialized
PostPosted: Fri Sep 03, 2004 1:38 pm
Smithfield*
Smithfield*
you have 4 HD's hooked up through IDE? make sure the master/slave jumpers are set correctly, and the disks are properly formatted. If you have any of them hooked up to tertiary IDE connectors, make sure that those IDE connectors are enabled in the BIOS. In my Mobo, i have 4 IDE connectors, only the first two are enabled by default. The other two (which can run in RAID or not) have to be turned on and told in which mode to run in the bios, for instance.
Also, instead or looking under system information, do this:
Control panel -> administrative tools -> computer management
then, under the heading "storage", select "disk management", and see what it says, and let us know. If the drives show up there, it might be as simple as formatting.
PostPosted: Fri Sep 03, 2004 1:40 pm
Smithfield*
Smithfield*
Flytrap, why is it that we seem to be going the same place, but have different directions on how to get there? Great minds think alike I suppose.....then again fools seldom differ....Not sure where that leaves us, but at least it's good company! :wink:
PostPosted: Fri Sep 03, 2004 1:48 pm
I suppose it's all in how you originally set up your machine. I prefer to have the Administrative Tools on my start menu.
PostPosted: Fri Sep 03, 2004 2:06 pm
and you parititioned and formated these drives right??
and if you did...how did you do it??
PostPosted: Fri Sep 03, 2004 2:29 pm
Team Member*
Team Member*
I'm with furball on this i think its a formatting issue. Can you format them from Disk Managment?
PostPosted: Fri Sep 03, 2004 2:52 pm
All the drives have bean partitioned and formatted through windows setup and the SATA contrller programs...I just found out that they are Unallocated, any help on that?
PostPosted: Fri Sep 03, 2004 3:57 pm
Just go into Disk Management and assign them a drive letter.
PostPosted: Fri Sep 03, 2004 6:09 pm
Yes they can. I just did it at my work. I found out that the person who configured our Win 2000 server never formatted the entire hard drive. We were getting seriously low on storage, then I when in to see how much we had and to defragment it. In Disk Management I noticed that there were over 83 gb not formatted.
I called the person who did it and he said he did not have the time due to time limitation on when server was required. I took care of if and now we have plenty of room.
PostPosted: Fri Sep 03, 2004 9:29 pm
YES thank you peeps......I just had to give the drives a name and assign them a "volume" now they are running smooth
