It is currently Thu Jan 29, 2015 5:50 am
 Post subject: Help Random Restarts and sometimes restarts before reboot
PostPosted: Mon Aug 30, 2004 6:09 pm
I have installed a new Audigy 2 Gamer, I have reinstalled it 3 times already, and Sometimes I get a random reboot, sometimes it won't even get to log on screen and reboot itself again, when I send an error report it says the problem was causes by a bad graphics driver, how can I fix this, I have tried reinstalling the drivers and nothing worked.
PostPosted: Mon Aug 30, 2004 6:19 pm
system specs?
PostPosted: Mon Aug 30, 2004 6:34 pm
2.8GHZ P4
Radeon 9700
Audigy 2 ZS Gamer
512MB RDRAM
12V Power Supply
PostPosted: Mon Aug 30, 2004 6:36 pm
if you take the card out does everything magically work again?
PostPosted: Mon Aug 30, 2004 7:49 pm
I took it out put it back in and now it makes a wierd noise but it is working, usually the VPU recover message comes up saying a driver isn't working and that i need to restart, usually the screen is like ripped apart and lines everywhere.
PostPosted: Mon Aug 30, 2004 8:41 pm
uhhh...this sounds like a videocard problem
PostPosted: Mon Aug 30, 2004 10:15 pm
Team Member Top 100
Team Member Top 100
I try to do the easy stuff first....look in the device manager for conflicts. 8)
Fold Until A Cure
PostPosted: Mon Aug 30, 2004 10:35 pm
Did you take out the soundcard or the videocard and put it back in....im sorry im confused here.
PostPosted: Tue Aug 31, 2004 10:58 am
Well it works now..
PostPosted: Tue Aug 31, 2004 8:24 pm
What kind of wierd noise are you talking about?
Users browsing this forum: oldwizkid and 12 guests
