It is currently Sun Jan 25, 2015 9:34 am
 Post subject: can't open any MS apps
PostPosted: Mon Aug 30, 2004 7:58 am
Don't shoot me; I don't have many specs since this isn't my comp. It's a store bought PC running Win XP Home. It used to work fine, however, now the MS apps won't open (IE, explorer, recycle bin...). I get the error message that the app has encountered a problem and needs to close, and it gives me the option of sending an error report. I've checked for viruses. All of the non-MS/non-preinstalled apps work fine.
PostPosted: Mon Aug 30, 2004 8:14 am
try booting up with the winxp home cd and choose repair on the main console. when you get to the black screen prompt, type in "chkdsk /r" and let it run. then reboot the computer and boot into windows. see if that fixes the problem.you will need to change the boot order in the bios first of course. set the first boot device to cdrom.
you can also do a system restore on the computer. backup the files and do a system restore. also you can try uninstalling the MS stuff and install them again and see if that fixes it also. another is do a system restore. backup the person's files first and do a system restore afterwards.
 Post subject: it just gets better
PostPosted: Mon Aug 30, 2004 10:25 am
Ran a check disk (setup in Windows to run on reboot) which did nothing. Can't do much for repairing, since I don't know the admin password. heh. Tried a restore as far back as possible, and that didn't fix it... apparently it's been a problem for a while.
PostPosted: Mon Aug 30, 2004 1:22 pm
honestly at this point i would just do a reinstall..obviously something is corrupt on your install.
You could try going into start/settings/controlpanel/system/advanced/error reporting. And disable error reporting. Maybe it will leave you alone.
PostPosted: Mon Aug 30, 2004 2:18 pm
create another user account and see if the problem is there as well.
